Clutches- Organic, Rigid, Sintered, what hell that all mean?
Old Oct 16, 2006 | 10:22 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Default Clutches- Organic, Rigid, Sintered, what hell that all mean?
As per title.
2 clutches here, one says "rigid sintered plate" one says "rigid clutch plate with organic facings" whats the difference?
I take it the rigid sintered plate is the uprated one or summat?
Ta
Old Oct 16, 2006 | 10:48 AM
dojj's Avatar
dojj
Resident Wrestling Legend
it's all to do with the compound of the clutch material isn't it?
like brake pads they have different materials for use with different applications
the rigid plate means its got no springs on it, so the clutch will be harsher when engaged
Old Oct 16, 2006 | 10:50 AM
dojj's Avatar
dojj
http://www.ramclutches.com/Clutch%20U/cl_u_3.htm
here you go
Old Oct 16, 2006 | 10:53 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
so they likely to be both uprated clutches then?
but sintered one is the super harsh one?
Old Oct 16, 2006 | 10:57 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
Sintered means that it is made with a powdered metal compound (same as brake pads), and is very aggressive and harder wearing....
Old Oct 16, 2006 | 11:06 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
the rigid means both are spring-less right? so harsher than std?
what do uprated covers do? as IIRC for this particular one there are uprated plates around, but not covers?
Old Oct 16, 2006 | 11:24 AM
dojj's Avatar
dojj
more clamping force
if you have a clutch that can withstand more torque being transfered through it, then thats only going to be able to be used with a cover plate that can clamp it more effectivly
not so much of a problem with a hydrulic clutch, but with t cable opperated system you'll need bigger legs to operate it (or use a longer pivot/moment/some physiscs thing i can't rememebr like fulcrum or somethng)
Old Oct 16, 2006 | 11:33 AM
Fiecos Dan's Avatar
Fiecos Dan
I thought rigid was the old way of doing plates.
As will not help gearbox breakages etc etc, as no springs to reduce the shock.
Old Oct 16, 2006 | 11:42 AM
Stavros's Avatar
Stavros
DEYTUKURJERBS
Its an old car danny, well, early/mid 80s, so no springs might just be the way it is.
deathrider666
Sep 28, 2015 06:12 PM
3doorcozmess
Sep 20, 2015 06:15 PM
muz
Aug 16, 2015 12:57 PM
