Diesel Experts! Smokin Weasel!
Old Oct 15, 2006 | 07:46 PM
shane's Avatar
shane
Default Diesel Experts! Smokin Weasel!
Ive just bought an Escort 1.8 Diesel van,it seems to smoke alot!Ive given it a service and its helped but it it does smoke abit still! It takes a while to start as aswell as the heater plugs are in need of a change, ut would this cause it to smoke when running?
When i say "it smokes" its not plumes but just like its runnin rich and its smells of fuel not oil!
Help much appreciated!
Old Oct 15, 2006 | 07:51 PM
DazC's Avatar
DazC
Heater plugs will not have any affect on the smoking issue when it's running on all 4 pots.
What colour is the smoke?
Old Oct 15, 2006 | 07:52 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Default Re: Diesel Experts! Smokin Weasel!
pump timing or funny fuel?
Old Oct 15, 2006 | 07:55 PM
Graceland's Avatar
Graceland
Team HOTHOT!
Sounds like the pump timing is slightly out,
try adjusting the vernier style pully on the fuel pump pully and see if it gets any better - it may be that someone has not tightened the 3 allen key locking bolts properly after replacing the cambelt and fuel pump belt, and the pully has slipped on its clamp
Old Oct 15, 2006 | 07:59 PM
shane's Avatar
shane
Funny Fuel? It has been sat for bout 6 weeks or so and the fuel init was the last and driving it home it was on the verge of running out and when i changed the filter it had sucked some of the shit out of the tank up!
The smoke is black/blue! And it does miss a little at first when started but otherwise runs fine!
Also can u get manuals for these engines? As im not clued up on diesel engines!
Thanks!
Old Oct 15, 2006 | 08:11 PM
shane's Avatar
shane
Il give that a go Graceland! But im not gonna do any damage getting it wrong am i? As it will be trial and error i guess!
Old Oct 15, 2006 | 08:14 PM
DazC's Avatar
DazC
All you will do is make it harder to start/diesel knock/smoke worse if you go the wrong way. Completely reversable by turning the pulley the other way and won't do any damage.
Old Oct 15, 2006 | 08:16 PM
shane's Avatar
shane
Thanks guys im hoping this will sort it!
DavidK
Sep 27, 2015 02:55 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
atm
Sep 7, 2015 05:39 PM
Bighandsuk
Sep 2, 2015 05:23 PM
