HELP PLEASE RE ABS!!
Old Oct 15, 2006 | 02:25 PM
Default HELP PLEASE RE ABS!!
...just noticed the bulb was disconnected..as obviouisly abs up the shoot ....There is no PUMP noise with ign on or when running?...Where is the ABS relay and fuse first off?????..i know where the ECU is.
Old Oct 15, 2006 | 02:40 PM
Jay,'s Avatar
Jay,
Sponsor
behind the glove box phil on a bracket bolted to the bulk head
Old Oct 15, 2006 | 02:43 PM
dave cos4x4's Avatar
dave cos4x4
should be pretty close to each other Phil.
Old Oct 15, 2006 | 03:16 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
the abs doesnt make a noise phil, its the servo pump that should buzz.but only when it needs some vacume.does your servo work when driving?>
Old Oct 15, 2006 | 03:22 PM
Eagle's Avatar
Eagle
Super Moderator
jay is the daddy of cossie abs systems
Old Oct 15, 2006 | 03:52 PM
Jay called and ran me thru some tests
...Pump is working and all sensors are within the ohms range....
Whats next?
Old Oct 15, 2006 | 03:56 PM
Jay,'s Avatar
Jay,
Sponsor
ac voltage should be .15v at 30/40 mph phil check that next on the pin outs i give ya
Old Oct 15, 2006 | 05:17 PM
RS500/364's Avatar
RS500/364
rear driver side sensor then front drivers
Old Oct 15, 2006 | 05:20 PM
...all sensors are operational mate.
Old Oct 15, 2006 | 05:44 PM
Jay,'s Avatar
Jay,
Sponsor
the next check is the loom the mate see if theres any continuity probs
Old Oct 15, 2006 | 08:11 PM
foreigneRS's Avatar
foreigneRS
Testing the future
tankybaby66
Feb 6, 2016 02:24 PM
muzzman1
Sep 30, 2015 08:59 PM
