heated front screen instalment to a 2004 TDCI sport!
Old Sep 28, 2006 | 01:18 PM
paceo's Avatar
paceo
Default heated front screen instalment to a 2004 TDCI sport!
as winter is coming up and i have to start work at 4am i am looking for a heated front screen for my ford focus tdci 2004 sport- some came with the optional heated front screen but mine has not.
can you tell me if the wiring loom will be there at all? so i can just get a heated screen and plug it up? or will i have to buy loom from ford? obviousy ill need to find a switch.
rob
Old Sep 28, 2006 | 02:03 PM
dojj's Avatar
dojj
Resident Wrestling Legend
get a screen
get a loom
plug it all in
stand back and be amazed as you screen clears
if you can get the, ford also do heated washer jets, on the 90 spec and onwards sierra's and granadas they were in the same loom
it's all stand alone for those cars (got one sitting in the front garden at the moment and it's a peice of cake to wire up, positive, negative, screen, switch, ecu idle up job done) so if you are lucky the focus will be the same
C2 MAK
Aug 20, 2015 09:46 PM
