ACTUATOR HELP
Old Sep 21, 2006 | 01:27 PM
SaqsS2turbo's Avatar
SaqsS2turbo
Default ACTUATOR HELP
AA
Old Sep 22, 2006 | 11:45 AM
LEE-RS's Avatar
LEE-RS
Custom
your actuator sounds fooked should be hard to pull out
Old Sep 22, 2006 | 11:58 AM
allbluepete's Avatar
allbluepete
had the same on mine rod moved in and out easy mate, car would not boost at all,fitted new actuator and fine now
Old Sep 22, 2006 | 12:24 PM
SaqsS2turbo
Old Sep 22, 2006 | 12:27 PM
SaqsS2turbo
cos after fiting a turbo to myns she dont boost at all boost gauge wont go over 0 psi
Old Sep 22, 2006 | 12:38 PM
SaqsS2turbo
the pipe that come off the bleed valve/t-pieace etc and go onto the actuator do i have to keep it on actuator or can i just set the actuator to one place to run some boost and leave the pipe off??
Old Sep 22, 2006 | 01:21 PM
heeman10's Avatar
heeman10
If you don't connect the hose back onto the actuator it'll make whatever boost it wants!!
Old Sep 22, 2006 | 01:28 PM
SaqsS2turbo
wot if the rod was welded
Old Sep 22, 2006 | 01:30 PM
heeman10's Avatar
heeman10
Welded anywhere in particular? To anything??
Old Sep 22, 2006 | 01:31 PM
SaqsS2turbo
nli want to run about 6 psi
Old Sep 22, 2006 | 01:33 PM
SaqsS2turbo
the rod on the actuator welded so it cant move in and out as itsa fuked any way
is that any harm for a solid rod
Old Sep 22, 2006 | 01:43 PM
heeman10's Avatar
heeman10
Do you mean weld the actuator rod so it can't move in or out? If that's the case, it would be just as bad as leaving the hose off the actuator, and the turbo would keep on boosting till you lifted off. Great way to destroy an engine and its turbo.
Old Sep 22, 2006 | 01:44 PM
SaqsS2turbo
just wondering dude no need for excitment
Old Sep 22, 2006 | 01:45 PM
heeman10's Avatar
heeman10
I wasn't aware of being excited. Ho hum, good luck with it all!
Old Sep 22, 2006 | 01:47 PM
SaqsS2turbo
cheers
Old Sep 22, 2006 | 04:33 PM
heeman10's Avatar
heeman10
Looks like a lot of embarassed editing has been going on!
Old Sep 22, 2006 | 04:43 PM
SaqsS2turbo
funny
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
