Cosworth Parts needed (more bits needed)
Need
A rebuilt t3 in standard trim with a 360, no 100,000 smoker
Ignition amp
mongoose 2wd down pipe
brake lines that run accross the bulkhead
petrol tank and sender
4x4 loom (no silly prces and not fooked)
Good T5 Box (no shonky wining thing or unuseable 3rd gears)
Accelorator cable
clutch cable
accelerator pedal
Thanks
Ignition amp
Accelorator cable
clutch cable
accelerator pedal
Thanks
JoeyBoyden
Jan 4, 2024 02:36 PM
