Specs on Brom's car?
10 inches? that's like 30 cm then
i guess that would affect the overall balance in the car as the 3dr is just a tad tailhappy..
must consider that as an alternative during winter rebuild then
another idea i had was to move the pedalbox/steering/seat back 5-10".. or 20-30 cm
could do both.. just to get even more to do..
Did he get 50/50 weight distibution? or whatever he was aiming for..
I think i read the thread about approx 600 bhp and nos.. gotta love stupid ideas like that..
And yeah.. forgot to ask about pictures..
Originally Posted by Itsmeagain
I think EVERYTHING is moved back, inc pedals, steering, seat, the lot
hi mate will be posting pics real soon
the whole car has been modded engine back 10 inch
front track widend (one off xmeber)
hight ajustable stering rack
boths seats are all the way back on and the floor
gotbias pedel box also moved back with the sterring aswell
basicly eveything from the gear box has been made from scratch nothing ford all fabritcated by me
engine spec
fardon inturnals
cozzy racing pistons
large ported head 28 inlet 26 exhuast
bd 16 e inlet and bd16 exst cams
dry sump
twin water injectoin set up
,gt35/40 hybred
external wastegate
hauser racing plenum
1000cc injectors
s8 mangment
4 2wd intercoolers welded together (temps on track yesterday were 24)
revs to 8800
runing 1.2 bar boost at min cuz of gearbox waiting for 6 speed tremec then boost will be 2.5 bar
running 500 plus at the min on low boost
target fig on full boost is 620 ish
then theres direct port noz ontop with 160 jets already in the engine again waiting for gearbox aswell
anything else you want to know mate
i will post loads of pics up soon theres a doug sterling post with the engine bay in there if you wana look at that
engine spec
fardon inturnals
dry sump
,gt35/40 hybred
external wastegate
1000cc injectors
s8 mangment
revs to 8800
Originally Posted by Shings
Unless I was sitting back further than normal he defo wasn;t any further back round at Karls the other day
Cheers for the reply..
i will probably ask more when i see some more pics..
I guess that the handling was improved since the engine is way back..
how is the weight distribution? 50/50?
i am relly curious to see how the car is built up and i hope there will be some high res pics of the engine/interior etc later..
And i found that pic of the enginebay and yes, i saved it
oh yes sorry mate
50/50 weight split with out fuel and me in it
am a very big lad so if deffo more to the rear
the problem with 3doors is there are tail happy due to no weight and also like escort cozzys if you aint got the power on they try to push on in the corners due to front end weight over the axle at the front
moving the engine back behind the centre line of the front wheels transorms the car
it turns in real fast now and when i got the hang of the car will be mint for drifting
tell me what pics your after and i will send you some mate
if you do a search on my posts theres loads of pics been posted while it was being built
The car looked awesome Brom, i had a look when it was parked up in the pits, id just been out in Newts escy cos
That 3dr is a credit to you mate, for all the man hours & hard work gone into the project
so when you're in it it's more like 30/70?
i know about the tailhappy 3dr as i have one myself..
was it "easy" moving the engine back? know it must have been a lot of labour but did you get any big problems?
did you build the transmission from the gearbox and back yourself? i know the Zoo does transmissions..
I am looking for the kind of pics that shows how you have done this and that.. you know, the technical stuff..
Will do a search thou..
Found a couple of pics (approx 50) but man, you post too darn much.. went through 20 pages of post where you had written something...
Is the jag diff a heavy b*stard? guess it take take some abuse thou..
btw: how much does the car weigh approx?
engine spec
fardon inturnals
dry sump
,gt35/40 hybred
external wastegate
1000cc injectors
s8 mangment
revs to 8800
engine spec
fardon inturnals
dry sump
,gt35/40 hybred
external wastegate
1000cc injectors
s8 mangment
revs to 8800
now all the pipes are in for the dry sump and all fluids its around 1200 if i remeber
the jag diff weights 60 kg but then again its 10.25 inch and low weight on the middle of rear axle is where you want it
Yeah, was gonna comment on the fact that you give out details about the build, not the average "yeah, it's a car.. yes it has an engine...."
especially since you do this for a living.. (i guess)
1200 kgs? how much is the rollcage? i have a 3dr, stripped out, no cage, and it weighs 1060 with 3/4 of fuel... but it's quite slow anyway so it wont do me any good...
You asked me what i wanted pics of.. well, everything basically...
but i guess that would be too much to ask...
but for a start it would be cool to see some pics of the enginebay and interior..
if you want to send some by mail: robert@lenangen.com
feel free to fill my inbox..
especially since you do this for a living.. (i guess) 1200 kgs? how much is the rollcage? i have a 3dr, stripped out, no cage, and it weighs 1060 with 3/4 of fuel... but it's quite slow anyway so it wont do me any good...
engine spec
fardon inturnals
dry sump
,gt35/40 hybred
external wastegate
1000cc injectors
s8 mangment
revs to 8800
engine spec
fardon inturnals
dry sump
,gt35/40 hybred
external wastegate
1000cc injectors
s8 mangment
revs to 8800
fucking hell man this is some spec
pics pics pics we need more some pics
Hi chaps,
was reading the spec on Broms cossie(Nice) remember seeing his sapphire cosworth @ donny park, went down with cruisenotts what a car but this one top car.
Question : The moving back of the engine, in the 1980s they did this to the RS 500 touring cars didnt they for better handling YES NO??????.
Brom you going to come down notts one sunday to show it off???????.
sorry mate been very buzy moving worshops to bigger premises
i will do a search and get loads of links up for you
failing that
go to photobucket and put cozzybrom theres loads there
failing that
gotta go, got some picbrowsing to do....
(ok, sorry photobucket, but you guys didn't resize the pics.. my bad...
JoeyBoyden
Jan 4, 2024 02:36 PM
Graceland
Jul 31, 2015 10:34 AM
