Reprogramming a wireless key fob for a Ford Puma
Old Sep 1, 2006 | 06:06 PM
Phil M's Avatar
Phil M
Default Reprogramming a wireless key fob for a Ford Puma
Can anyone help with the reprogramming of a key fob for my wife's Puma
I have reprogrammed the fob to start the car but cannot get the remote to work for the locking/unlocking of the doors.
I have tried a method from the Internet which was to turn the ignition on and off 4 times then press the lock button until the open door buzzer sounded and the fog lamp switch lamp illuminated, you then pull the key out of the ignition and it should work......when I tried this method I could not get the door buzzer to activate.... can anyone help?...thanks
Old Sep 1, 2006 | 06:24 PM
M1CH43L's Avatar
M1CH43L
its not one where u have to do it realy quickly is it
if it dont work u might have to go ford to get fob to work i think
Old Sep 1, 2006 | 06:39 PM
Phil M's Avatar
Phil M
Default Not too sure mate...I have tried everything
Old Sep 1, 2006 | 06:48 PM
Doug's Avatar
Doug
Phil The above resync method that you have mentioned is the correct proceedure how many keys do you have that have fobs built in ?
Ignition on and off in quick consession untill chime sounds press lock unlock button in sucsesseion ....................... If you have a second key you will have to carry out the same proseedure immediatly after the 1st key to programme ........
Regards Doug .
Old Sep 1, 2006 | 07:07 PM
Phil M's Avatar
Phil M
Doug, thanks for the reply I will try the fast on/off of the ignition until the buzzer works ... I only have a new key fob which requires reprogramming which I purchased from Ford to day.....the old key fob still works although it does require a lot of effort on the buttons
Old Sep 1, 2006 | 07:14 PM
Phil M's Avatar
Phil M
Doug...you are a star it now works fine I owe you a pint mate ...cheers
Phil
Old Sep 1, 2006 | 07:45 PM
Doug's Avatar
Doug
Your welcome mate glad its sorted
Regards Doug .
rst-s1
Aug 23, 2015 07:56 AM
Daisychain
Aug 22, 2015 08:12 PM
borboyous
Aug 22, 2015 11:17 AM
tankybaby66
Aug 9, 2015 07:13 AM
