fuel economy - how to improve it?
Old Aug 30, 2006 | 06:21 PM
haz87's Avatar
haz87
Default fuel economy - how to improve it?
its shite basically
Doesnt matter if i drive carefully for days on end or have my foot stuck to the floor, im gettin about 200miles to a tank either way and im sure thats a hell of alot worse than my old 3i.
What kinda economy are you all getting and what would you recommend to help improve it? Except the normal general service items
Mfi xr3i btw
Old Sep 11, 2006 | 09:12 PM
daveselwood's Avatar
daveselwood
Default pills
have you tried ffi fuel pills im getting an extra 10 % per tank and they lower the emmisions.ill try and get you the web address or just search ffi
Old Sep 11, 2006 | 09:42 PM
costina's Avatar
costina
Live long and prosper!!
sounds like its running rich.thats a lot of fuel being wasted i found cheap fuel dose less to the gallon aswell
Old Sep 11, 2006 | 10:10 PM
Wardy257's Avatar
Wardy257
First thing is to check everything is working perfectly. Plugs, leads, oil, vacuum pipes, cooling system, sensors and so on. Ones that done you can look at uprateing or replacing old parts for new.
Old Sep 12, 2006 | 10:00 PM
Rick's Avatar
Rick
You need to check the AFR. It is probably running rich due to past fiddling.
Old Sep 17, 2006 | 07:50 PM
MarkN's Avatar
MarkN
Check that the diaphragm hasn't split in the vacuum advance unit on the side of the distributor. You'll have to get a bit of vacuum hose, attach it to the advance unit and try to suck through it. If you can suck air through it the diaphragm is split and the advance unit needs to be replaced.
I've had a couple like this and replacing them makes a massive difference to the fuel consumption and power too.
Mark
timsrs
Nov 13, 2018 11:48 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
20/20 vision
Sep 29, 2015 11:27 AM
SMILER258
Sep 28, 2015 09:04 AM
