Weird cosworth?
Old Aug 24, 2006 | 06:24 PM
cosmatt's Avatar
cosmatt
Default Weird cosworth?
Please help, just put new loom in 2wd saph and think its out of an escort cos,as its got plugs for lambda. My problem is when i connect the icv up the car goes nuts,and the rev counter takes a life of its own until the engine eventually dies. When turnin ignition on with it connected it cleans itself( i think). Are the icv`s different? Why affecting the rev counter ?
Old Aug 27, 2006 | 07:35 PM
cos jon's Avatar
cos jon
Was everything ok before changing the loom ??
Old Aug 27, 2006 | 09:29 PM
costina's Avatar
costina
Live long and prosper!!
Yes they are different i think are you running your std L6 ecu if so think the TPS sensor wires will require swapping (outer wires)
cos when u use a L8 ina 2wd saff you need to chenge um the other way and use a PF09 TPS(4x4 sensor)
also later looms have a knock sensor located LHS lower block on or near to the bung u take out for breather oil return
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
