Escort radiator problem?
Old Aug 21, 2006 | 12:58 PM
Lee1's Avatar
Lee1
Default Escort radiator problem?
Hi all ive got a problem i have a Escort 1.6 16v when ticking over gets warm and the fan dont cut in. Also the water is brown in the header tank. I was thinkin it could be a blockage but not sure. any help would be appreciated.
Old Aug 21, 2006 | 05:35 PM
HORNETS7's Avatar
HORNETS7
if the fan dont kick in try removing the plug from the thermostat sender and bridge the 2 wires with a link wire!
if the fan comes on then u know the thermostat sender is knackered
if the fan dont come on the the fan or wiring is fooked
Old Aug 21, 2006 | 07:01 PM
Lee1's Avatar
Lee1
ok nice 1 i'll give it a go
Old Aug 22, 2006 | 07:50 PM
Lee1's Avatar
Lee1
thought this was supposed to be a helpfull site? ive had 18 views and 1 fookin reply!!!!!!!!!!!
Old Aug 22, 2006 | 10:43 PM
SafeChav's Avatar
SafeChav
Firstly as said you need to find whether the switch is at fault or whether its something else in the circuit.
You will find the fan plug on the radiator just below the top hose, bridge that with wire.
The fan will take quite a while to kick in at idle however.....does it actually over heat?
As for the coolant being brown, its obviously been run with water in for a period of time, drain the system, run a hose pipe inside to flush everything out and then put in anti-freeze, top up to level with water and run the car to temperature with the cap off.
Old Aug 23, 2006 | 12:32 PM
Lee1's Avatar
Lee1
does'nt acctually overheat but the engine gets really hot just ticking over. just thought id let everyone know if they aint seen it the rollin shell for F55 SOY is for sale on ebay saw it 2day.
Vincereese
Jun 1, 2023 09:14 AM
SmudgerByName
52
Jul 28, 2016 06:14 PM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
Vincereese
Aug 16, 2015 06:38 PM
