trouble with brakes..
Old Aug 20, 2006 | 02:17 PM
kinglooy's Avatar
kinglooy
Default trouble with brakes..
I have just changed my front brake pads on my escort but the brake peddle seems spongey. Is there anything i should of done when changing, all i did was just take old of new on..
Old Aug 21, 2006 | 09:33 PM
steve87's Avatar
steve87
hopefully your new pads just need bedding in.
but if you didnt take the cap off the top of the brake fluid bottle when you pushed the piston in the calliper back (to allow for your new thicker pads).
you may have put too much fluid pressure through your brake system.
have you noticed any brake fluid leaking
my guess is that if you have done this, it would have cracked the brake fluidbottle so check for a leek there.
hopefully just need beding in though
other than that i cant think of anything else that yu can do wrong.
hope this helps
IainRS1700T
Sep 25, 2015 06:44 AM
oilman
Trader Parts for Sale.
Sep 23, 2015 11:21 AM
fordjames
Ford Focus Diesel
Sep 3, 2015 10:20 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
