my s2 to efi conversion small update 10/02/07
done this cos iam fed up of my mfi system playing up all the time
ok old loom out as iam changing the complete loom to a xr3i efi one
efi parts arriving
inlet manifold
bottom pully,alternator pully and mounting bracket
sierra cvh cam cover
edis module and coil pack
acclerator cable and pedal
all mfi parts removed off engine
pully and cam cover modified to fit
now the rebuild
bottom pully fitted
loom nearly finished
cps fitted
nearley there
new fuel feed pipe
a bit of paint and its done
just the rusty arch to do now
efi parts arriving
inlet manifold
now the rebuild
bottom pully fitted
cps fitted
nearley there
new fuel feed pipe
it boosts alot smoother doesent feel as raw but its over fueling ( black smoke on boost ) so setup is next
but the starting issues i have always had are all gone fires up first attempt that was the main reason for me doing it
sierra cvh 1800 bottom pully machine work needed
sierra 1800 chv cam cover with cps cover need to be cut down
mfi to efi adapter plate or efi head
fiesta turbo inlet manifold c/w injector wiring fuel rail etc
xr3i efi 1990 loom cps wire needs extending and the fan plug will need to be extended and the origional plug used
fiesta turbo charge carrier and 90 spec rockercover
ofac fiesta turbo ecu and map sensor for ease of fitment
accelerator pedal off a carbed mk4 escort and cable from a zetec escort
sierra 1800 cvh alternator mounting bracket and adjusting arm also u will need the alternator pully
thats just roughley off the top of my head
been a while since my last update cos of health problems
arch repaired
should of checked the other side before it went in
got my s1 kit ready to be fitted
progress is slow but its getting there
arch repaired
mk3ste
Oct 17, 2021 10:09 AM
SMILER258
Sep 28, 2015 09:04 AM
