RS1800 Central Door Locking Problem !
Old Aug 16, 2006 | 02:15 PM
ChrisRS1800's Avatar
ChrisRS1800
Ka Turbo
Default RS1800 Central Door Locking Problem !
Hello all, im hoping someone here mite be able to help.
Having problems with my CDL, when i lock my doors from the drivers side i get nothing but when locked from the passenger side the doors lock fine. I have replaced both mechanism and motor in the drivers door, yet still having the same problem.
Any ideas ???
Old Aug 16, 2006 | 09:10 PM
Dave Henshall's Avatar
Dave Henshall
have you located the clip on plastic roung correctly around the barrel that contains the sliding contact for the central locking - it can be fitted back on with the post not located and so will either lock and not unlock or vice versa - depending which way round the post was - it need to sit in the middle of the plastic clip - its a bit fiddly to do in the door skin though
Old Aug 17, 2006 | 09:25 AM
ChrisRS1800
Ka Turbo
Rite me central locking is all fixed nw
The problem was the N/S central door locking motor, would neva av 4rt this would cause the prob bt i just replaced that and it is all working fine now
PaulinhoT
Oct 28, 2015 06:06 PM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
Seanyfarrell
Aug 14, 2015 11:37 PM
tankybaby66
Aug 9, 2015 07:13 AM
