uneven tyre wear
both front and rear off side tyres on my 170 are wearing badly on the inside 1mm , 5mm in middle , 4mm out side is this just a tracking issue ? how do you adjust the rears . how much will it cost ? thanks
Hi,
It's a common fault on focus's for the rears to wear unevenly on the inside, thoughout the range. It's just the way the they're set up, when i got my RS the rear tyres looked like fifty pence pieces.
