FAO: Alarm fitters/experts
My alarm has been playing up since the really hot weather started. Earlier on I felt the alarm unit and it was roasting hot (as everything else under the bonnet was) and just wondered if its the extreme heat thats causing it not to respond to the remote (fitted new batteries to both remotes this afternoon btw)?
Cam, Electronics dont like heat above about 50 to 70 C.
Could be your alarm could have been warmed up by air flow in the engine
bay coming from the radiator warming up air that is already over 30 deg C.
Let it cool naturally and it will probally recover and may need
completely powering off (Vehicle battery and internal battery if fitted)
Originally Posted by lloyd
when you replace the key fob batteries dont you have to reprogram the alarm to recognise the signal? sure thats what my clifford instruction book says,?
New alarm time me thinks and it will not be another Clifford thats for sure.
