Kent RSOC Meet ?
Hi Steve,
i'm doing a trackday this saturday @ Lydden, Should be a good crack if your free.
https://passionford.com/forum/viewto...23ebf6eb6b6066
I'll be htere, Baptist will be in attendance, as will the artist formally known as Andy RST and Darren S2 in his Cossie
Should be there for 8.30 sharpish if the Baptist has done his hair by then
Steve are you going or not ??????????????????????
I am deffo going but not until a bit later, will be there about 8.30pm if putting the kids to bed goes smoothly
Come & say hello mine will be the only 3dr cossie ona Q plate
you won't miss it.
See you all later
Simon.
you won't miss it.See you all later
Simon.
I did manage to go in the end
But my bottom end started to knock on the way home
I still have the same oil pressure when driving and at idle also the water temp stayed at the normal temp as well.
Hope everyone had a better night than me.
Steve.
Steve.
Steve.
Steve.
On a serious note tho, hope its not too serious...
Steve.
Steve.
Steve.
Steve.
Steve.
STAFFY OWNER
Sep 13, 2015 08:59 PM
