A little something to interest you all ;)
Team HOTHOT!
Nice and grey
Getting there now people
Fuck me tho, spraying in this heat is a bastard, the paint drys before it hits the car if the gun is too far away or not enough thinners are used
Still tho, not bad for a mornings work, and with only 1 run i'm a bit chuffed for the priming stages
Team HOTHOT!
Well, the top coat is going to be applied on the 3rd and 4th of august, then testing etc etc etc, so it MAY be in attendence at Ford Fair
Got to take the intercooler and radiator back out tho sometime soon and replce the front crank seal
Team HOTHOT!
Originally Posted by Simon@FF
Paul, you are The Man.
I'm sending a PM to you for other reasons now too
top work mate, i know what you mean about the paint drying out, maybe use more thinners but be carfull as it will run like a nose
Keep saying it Simon when you are bent over touching your toes
Team HOTHOT!
I'm only doing the priming Steve, The topcoat I will leave for my trusty painter XR_Craig on here
He is a painter by trade
However, If I wanted to, I'm sure I could get a good finish on the topcoat, but would rather Craig did it
He is a painter by trade However, If I wanted to, I'm sure I could get a good finish on the topcoat, but would rather Craig did it
Dont use more thinners, it'll dry quicker!
You need to be spraying about 22º + or - 5º, anything more and paint dries very quickly!, Trust me
If the paints going on dry Paul, put another coat on until it goes on wet
You'll only need to redo it in a year or so again...
and there i was thinking you'd killed yourself by using spary cans
looking good mate, would love to see that turn up at ford fair and someone say "but thats not a ford"
Team HOTHOT!
Rad - The paint stayed nice and wet while I was doing it and the temp in the garage is 24 celcius, so not too bad then
Going to flat it all off tomorrow and give it another coat of primer too
