working with carbon fibre
Old Jul 18, 2006 | 01:37 PM
slowpoke's Avatar
slowpoke
Default working with carbon fibre
how easy is it to drill a hole in a sheet of carbon fibre say 52mm with a hole cutter on a drill ?
would it leave a neat hole of frayed ends all over the place ?
matt
Old Jul 18, 2006 | 01:43 PM
~nomad~'s Avatar
~nomad~
easy enough if you mask the hole right up and go slowly.
Old Jul 18, 2006 | 01:45 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
piss easy. done it loads, no harder than any other material with a decent hole cutter.
Old Jul 18, 2006 | 01:46 PM
slowpoke's Avatar
slowpoke
thanks guys
matt
Old Jul 18, 2006 | 01:49 PM
Ryan's Avatar
Ryan
as said easy with a hole cutter, do it outside well ventilated and where a mask, gloves and cover your arms, if its proper carbon, not the mickey mouse stuff.
Old Jul 18, 2006 | 01:53 PM
Paul Eggleton's Avatar
Paul Eggleton
If its proper stuff then the resin would have worked itself well into the fibres so nothing should fray.
Oct 9, 2015 07:38 PM
YODI
Aug 30, 2015 01:12 PM
big hyndy
Aug 28, 2015 12:49 PM
