Escort Cossie Nightmare!
Old Jul 18, 2006 | 12:37 PM
marleysdad's Avatar
marleysdad
Default Escort Cossie Nightmare!
Hi all. My escort cossie has broken down in the road outside my house (will turn over but wont start). The problem I've got is that I need to get it into my garage to fix it (My road is full of snobby gits who dont like seeing cars being worked on!) My drive is on an upward incline so what would be the best way to move it? Would putting it in gear and turning over on the starter be sufficient to move it? Am also worried what effect it would have on my PAS! Please help!
Old Jul 18, 2006 | 12:46 PM
St3V3_C's Avatar
St3V3_C
Steering will be fine, but it might be a bit heavy.
How steep is the drive? If it's not too steep you'll be fine, just don't keep it spinning for long without a rest, you could burn out the starter. At the risk of stating the obvious, use 1st gear.
Old Jul 18, 2006 | 12:51 PM
Graceland's Avatar
Graceland
Team HOTHOT!
have you checked the fuel inertia switch before you resort to pulling the car in bits
Old Jul 18, 2006 | 12:52 PM
marleysdad's Avatar
marleysdad
I certainly have, now gonna check sensors, etc once it's in garage
Old Jul 18, 2006 | 12:53 PM
St3V3_C's Avatar
St3V3_C
Large turbo Esc Cos - it's in the passenger footwell. Not sure on small turbo...
Old Jul 18, 2006 | 12:56 PM
R4N SS's Avatar
R4N SS
check the wires on the ign coil as this happended to me the other day after giving it some and ended up leaving the car at my mates house
Old Jul 18, 2006 | 01:21 PM
foreigneRS's Avatar
foreigneRS
Testing the future
remove spark plugs to give the starter an easier time of it
Old Jul 18, 2006 | 04:30 PM
JasonMax's Avatar
JasonMax
Had exactly the same problem with my EsCos 2 weeks ago. Had to wait nearly three hours for RAC, and then a low loader.
Turned out to be fuse box problems, very common on them apparently.
My car was turning over fine, but my fuel pump wasn't priming.
Old Jul 18, 2006 | 05:26 PM
vroooom ptssssh's Avatar
vroooom ptssssh
It Wasnt Me!
get some mates to help push it up the drive too
Old Jul 18, 2006 | 06:17 PM
ballin's Avatar
ballin
Fuck the neighbours!
Old Jul 18, 2006 | 07:04 PM
Phil DJ's Avatar
Phil DJ
U pay road tax so u have the right to work on ur car at the side of the road.
Tell ur neighbours to fuck off if they moan
Old Jul 18, 2006 | 07:06 PM
Ginge !'s Avatar
Ginge !
just finding my feet
erm,,,,,,,,,,, that aint quite true mate
Old Jul 18, 2006 | 07:11 PM
deleted's Avatar
deleted
From: learnin to build a yb lump properly in dennis's garage
there is a new law that says u cant work on the side of the road
peteh's Avatar
peteh
exactly what i thought your house you do what you bloody want on your drive
Old Jul 18, 2006 | 07:27 PM
matts1's Avatar
matts1
No, it is against the law
Billy_RS
16
Oct 11, 2025 09:41 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
FlashRS
Sep 14, 2015 12:36 PM
Vincereese
Aug 18, 2015 03:57 PM
stickyslick
14
Aug 10, 2015 06:27 PM
