zetec question
Old Jul 18, 2006 | 11:58 AM
749steve's Avatar
749steve
Default zetec question
is there any difference between a zetec with the starter on the front and one on the rear i.e can i fit a 2.0 with the starter at the rear to a mk4 gear box and mount the starter at the front
Old Jul 18, 2006 | 12:02 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
yes you can
Old Jul 18, 2006 | 12:05 PM
749steve's Avatar
749steve
cheers does it fit straight up,i know i need a 1.8 sump/oil pick up but is there anything else i need to do?
Old Jul 18, 2006 | 12:12 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
you will need an escort water pump, escort flywheel and clutch (not xr3i 130 as they are 240mm, you need 220mm)
you might have to use the escort altinator bracket and put in on the front of the block too
and then the wiring and management to run it
Old Jul 18, 2006 | 01:27 PM
dojj's Avatar
dojj
Resident Wrestling Legend
wouldn't the bigger clutch be better?
or will it not fit into the hole inthe gearbox bellhousing?
Old Jul 18, 2006 | 01:50 PM
Fudgey's Avatar
Fudgey
Baby Cheesus
the flywheel is too big to fit in the ib5 gearbox.
but if you got an MTX box then use the bigger fly/clutch
Neil Clark
21
Oct 1, 2015 07:02 PM
Fiddy
21
Sep 29, 2015 06:10 PM
focuspower
Sep 20, 2015 03:51 AM
BRAMMER
15
Sep 14, 2015 08:52 PM
andrewmctiernan
Sep 8, 2015 03:05 PM
