Small crank pulley
Old Jul 18, 2006 | 08:08 AM
Franco's Avatar
Franco
Default Small crank pulley
How the fuck do you get it off!!!!
I want to change the gasket behind the plate but i'm fucked if i can see how to get it off without fords SPECIAL TOOL!
Old Jul 18, 2006 | 08:23 AM
dojj's Avatar
dojj
Resident Wrestling Legend
if it's in the car you can remove the rad and use a normal puller
if it's out of the car you can forget about the rad and just use a puller
Old Jul 18, 2006 | 08:37 AM
Franco's Avatar
Franco
What if you havent got a puller small enough! mines too big........
Old Jul 18, 2006 | 08:40 AM
DaveEscos's Avatar
DaveEscos
must resist
Old Jul 18, 2006 | 08:46 AM
CosRush's Avatar
CosRush
You could buy a brand new of me still in its box
http://www.machinemart.co.uk/product.asp?p=040211223
Old Jul 18, 2006 | 08:48 AM
Franco's Avatar
Franco
Its for the small pulley though, it has no holes to mount that kit................
Unless i missed something?!?!?
The pulley i have is the big 3 legged puller.
Old Jul 18, 2006 | 08:49 AM
CosRush's Avatar
CosRush
Small crank pulley.........got any pix???
Old Jul 18, 2006 | 08:50 AM
Stu @ M Developments's Avatar
PassionFords Creator
Be prepared to smash the cover off.
Old Jul 18, 2006 | 08:51 AM
Franco's Avatar
Franco
Old Jul 18, 2006 | 08:53 AM
CosRush's Avatar
CosRush
ahhh got you.........
you're screwed then
Old Jul 18, 2006 | 08:54 AM
Franco's Avatar
Franco
Ahh then i can use the puller!! cushdy that'll mean i don't need to take the sump off!
Old Jul 18, 2006 | 08:55 AM
DaveEscos's Avatar
DaveEscos
hmmmmmm.. does look like a bit of a fooker doesnt it
Old Jul 18, 2006 | 08:58 AM
Franco's Avatar
Franco
Thats where most of the shite has come from.......
Looks like the original seal, as i had to use a wire brush on the oil pump pully fitting!!!
So its gotta come off!
Old Jul 18, 2006 | 09:01 AM
DaveEscos's Avatar
DaveEscos
think ive got a cometic front cover gasket at home..... and bits n bobs...
Old Jul 18, 2006 | 09:03 AM
Franco's Avatar
Franco
Have a peek mate, if you have stick whatever you dont need in the post & i'll square you up another slapup feed in the cafe!
I'll be smashing shit out of tonight!
Old Jul 18, 2006 | 09:04 AM
CosRush's Avatar
CosRush
Its not easy to tell from the pix but how much room is there underneath the pulley???
enough to get a head of a ground down HT bolt???
perhaps an M6 which could sit between the teeth in the recess keeping it close to the pulley body.
Just wondering if you could grind the heads to make them fit into the available space, then with them screwed into some steel with a central bolt, it may be enough to prise it off.....
but only if there's enough room.
Old Jul 18, 2006 | 09:06 AM
Franco's Avatar
Franco
You can get a mid sized screwdriver around the edge of the pulley.........
So anything bigger your stuffed!
DaveEscos's Avatar
DaveEscos
dont worry mate, next greasy spoon is on me... ill have a look and get it over to you
Old Jul 18, 2006 | 09:08 AM
Worst case scenario:
Order a new cover from a breaker.
Split teh old cover with a chisel.
Use puller to remove pulley.
Job done. 5mins. Simple.
Franco's Avatar
Franco
It aint true what they say about you!!
Old Jul 18, 2006 | 09:09 AM
CosRush's Avatar
CosRush
Split the old cover with a chisel.
Does seem the easiest solution by far...........
Just dont smack the pulley itself by mistake
Old Jul 18, 2006 | 09:10 AM
Franco's Avatar
Franco
Cheers Stu, deffo taking the easy smash shite out of route!
Old Jul 18, 2006 | 09:23 AM
CosRush's Avatar
CosRush
If you get stuck, just ring the fire brigade.....dont forget they do this for a living..........
Old Jul 18, 2006 | 09:27 AM
dojj's Avatar
dojj
why don't you just unbolt the cover and they use that to prise the puley off?
and is it a pulley or is it the timing belt sprocket?
Old Jul 18, 2006 | 09:30 AM
Franco's Avatar
Franco
Pulley...........sprocket..........You knew what i meant!!
CosRush
The missus would love for me to call the boys out to remove it!!
Old Jul 18, 2006 | 09:33 AM
CosRush's Avatar
CosRush
LOL
Old Jul 25, 2006 | 04:12 PM
CosRush's Avatar
CosRush
Did you sort this out ok in the end???
Old Jul 25, 2006 | 04:16 PM
Franco's Avatar
Franco
Yes i did thanks dude.......
Went for Stu's choice of the good old chisel option........ and smashed the livin bejesus out of it!
Then i could get the 3 legged puller on the pulley!
Old Jul 25, 2006 | 04:19 PM
CosRush's Avatar
CosRush
Good, im glad you got it sorted (and didn't bust anything else in the process )
Old Jul 25, 2006 | 04:21 PM
Franco's Avatar
Franco
it was similar to this pic actually, without the onlookers though!
Old Jul 25, 2006 | 05:44 PM
CosRush's Avatar
CosRush
LOL
Old Jul 25, 2006 | 07:03 PM
dojj's Avatar
dojj
so what happens if you DON'T want to break the cover?
how are you "supposed" to get it off without the "ford special megamoney for this job only tool"?
Old Jul 25, 2006 | 07:05 PM
CosRush's Avatar
CosRush
I think there would be only 2 options.........
you borrow one from Ford (if you know somebody who works there and they have one....)
or
you make one..............
Nov 1, 2015 06:53 PM
fordrallycar
Sep 30, 2015 07:57 PM
Fudgey
21
Sep 30, 2015 06:19 PM
youngben
Sep 27, 2015 09:37 PM
timsrs
22
Sep 24, 2015 08:14 PM
