!!!!!! URGENT !!!!!!! HELP NEEDED... immobiliser
Old Jul 17, 2006 | 09:30 PM
c.h.r.i.s's Avatar
c.h.r.i.s
Default !!!!!! URGENT !!!!!!! HELP NEEDED... immobiliser
Urgent as we are going on holiday tomorow !!!!!
my dad has got a problem with his immobiliser on his escort.
it is an aftermarket one with a slot in the dash where you place a little fob into, which then deactivates the imobiliser.
but he has just gone to start it but when he placed the fob into the slot nothing happend ( normaly a flashig LED goes out but nothing )
can anyone help in any way, like how to reset it...
will disconecting the battery reset it?
or is it to do with the little fobs..
its like this... first one on the page http://www.kleenacar.co.uk/carsecurity.htm
any help would be much appreciated
chris
Old Jul 17, 2006 | 09:49 PM
NUTS RuS's Avatar
NUTS RuS
Any joy yet chris ?
Old Jul 17, 2006 | 09:51 PM
c.h.r.i.s's Avatar
c.h.r.i.s
unfortunatly not
Old Jul 17, 2006 | 09:56 PM
mark_24v_wiring's Avatar
mark_24v_wiring
Disconnecting the battery may or may not do any thing always worth a try tho.
Do you have another dis arm fob to try just in case. Are the pickup contacts clean?
Silly stuff i know but worth checking.
Its prob a 2 point system so you can bypass it to get you outta trouble and it should not be too hard.
Only time i have had a problem with these types of imob i have had to replace them so it maybe worth bypassing it and booking the car in for a new one.
I know that leaves it unprotected but if you can drive it to your local alarm place they maybe able to fit a new one almost straight away for you
Old Jul 17, 2006 | 09:57 PM
king of bling's Avatar
king of bling
Maybe not the best solution but you could always call out an auto leccy me mate had a similar problem called one out he just by-pasted it..
Old Jul 17, 2006 | 10:04 PM
c.h.r.i.s's Avatar
c.h.r.i.s
both dis arm fobs wont work and we go on holiday tomorow so dont have time to take it any where,
well atleast no one will be able to start it whilst we are away,
thanks anyway guys
Old Jul 17, 2006 | 10:11 PM
NUTS RuS's Avatar
NUTS RuS
Is it new ?
What I mean is are you doing it correct ? Some need the ignition on, some need it off. Some have a time limit before they shut off, and some can be re-set by switching the ignition on and off say 5 times quickly.
Old Jul 17, 2006 | 10:14 PM
c.h.r.i.s's Avatar
c.h.r.i.s
no it was on before he bought the car, a mate had it before him. had it for about 3 yrs now and never had any trouble with it, until he went to start it before. so its not like i'm doing it wrong. ill try switching it on and off 5 times now
Old Jul 17, 2006 | 10:17 PM
c.h.r.i.s's Avatar
c.h.r.i.s
no tried switching the ignition on and off and still the same
Flatlinedan
Sep 18, 2015 12:41 PM
micky boy
Oct 9, 2004 01:56 PM
Walshy
May 14, 2004 01:34 PM
