carbon cannister
on the esc cossies how exactly does the carbon cannister work? i assume the fumes from the fuel tank are passed through this,neutralised then the solenoid opens and they are sucked back into the engine but what determines when the solenoid opens and for how long etc?also what is the valve that is connected up by the fuel filler pipe in the rear wheel arch for?always wondered and thought it was about time i found out,sure someone will know?
