how does anti-lag work
Old Jun 7, 2006 | 05:54 PM
TimC's Avatar
TimC
Default how does anti-lag work
as per title really.
how does it work?
iv been told anti lag cant be ran with a gt series turbo also, why is this?
sorry if i sound dumb, but you dont learn if you dont ask.
thanks.
tim
Old Jun 7, 2006 | 10:08 PM
SafeChav's Avatar
SafeChav
Im not the most clued up but it basically does massive amounts of ignition retard and loads of fuelling at idle to keep the turbo spinning.
Old Jun 7, 2006 | 10:12 PM
TimC's Avatar
TimC
so its sort of firing with exhaust valves open whilst inlet valves are shut, causing pressure in the turbo, therfore making it spin?
cheeRS btw
Old Jun 7, 2006 | 10:14 PM
SafeChav's Avatar
SafeChav
Something like that. It uses shitloads of fuel though and you need a GOOD turbo with a maram shaft to take the heat it produces.
Old Jun 7, 2006 | 10:20 PM
OvaBoost's Avatar
OvaBoost
Anyone else clear this up please? I wanna know also lol i have a basic knowledge
Old Jun 8, 2006 | 12:31 AM
biglee's Avatar
biglee
Audio specialist
what happens is.....
it massively retards the ignition to such a degree and ads extra fuel to an open chamber so when the plug fires the explosion goes out of the chamber and past the exhaust valve which is open at this time as its on the exhaust stroke....and the burning gasses blow past the turbo and keep it spining.....
its not quite that simple but its the basic...
speak to Karl Norris of NMS or Stu at MSD. they will help you
Old Jun 8, 2006 | 06:31 AM
CosRush's Avatar
CosRush
If you want some good indepth info, see my post titled 'How does ALS work???'
JK12
33
Apr 26, 2021 12:09 PM
Rstar_man
143
Jul 20, 2020 11:16 PM
