cossie clocks, dimmed lighting, help?
Old May 22, 2006 | 10:11 PM
AJC's Avatar
AJC
Default cossie clocks, dimmed lighting, help?
the clocks on my cossie are very dim, the adjuster is on full brightness.
the banana pod clocks are dim too.
the speedo is the lightest bit, is there anything to replace or is this
just what happens over time, my mates cossie has very bright clocks
it has done more miles and is an older car so i dont know why mine
are like this
cheeRs
Old May 23, 2006 | 01:44 AM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
I had the same problem: https://passionford.com/forum/viewto...light=#1867744
see here also: https://passionford.com/forum/viewto...light=#2358740
Cant get the invertor from Fords though, and there are two versions!
Got mine from someone off here so just ask around.
Old May 23, 2006 | 08:41 AM
Damo V's Avatar
Damo V
AJC
https://passionford.com/forum/viewto...asc&highlight=
This is the thread where you asked about it for your mate ...
As Lee said though cant get them any longer...
Old May 23, 2006 | 09:11 AM
AJC's Avatar
AJC
Damo V
cheers, he still aint sorted his, but mine are only dim,
his dont work full stop, is that caused by the same invertor?
Old May 23, 2006 | 10:04 AM
Rippers's Avatar
Rippers
Monte Geek
One thing that might make a slight difference, I noticed I couldn't see my oddometer reading at night and assumed because of the way they light up you couldn't see them.. untill I went in Franco's one which was lite up! So taking the dash surround there is a bulb aswell and since fitting it is a bit brighter
Old May 23, 2006 | 10:07 AM
EssexBoyRacer's Avatar
EssexBoyRacer
If ford have stopped doing the inverters you should be able to use one from another supplier.
Halfords sell EL inverters for their neon EL range of stuff. They're only a fiver and with a bit of modificiation should run a set of cossie EL clocks no problem.
Old May 23, 2006 | 11:33 AM
AJC's Avatar
AJC
just ordered a brand new invertor from ford
Old May 23, 2006 | 11:39 AM
Rolls's Avatar
Rolls
Interesting..... i don't think you can see my odometer at night either.....
Old May 23, 2006 | 01:00 PM
G1EN's Avatar
G1EN
Was going to say, they are still available from ford. A mate had this problem and he pick one up from fords.
AJC: How much was it out of interest.
Old May 23, 2006 | 03:12 PM
Lee1972's Avatar
Lee1972
Formerly COSSIE_LEE
I had one on order at Quickco in Borehamwood and Fords in Colindale but neither turned up after about 4 months so I gave up!
Old May 23, 2006 | 06:01 PM
AJC's Avatar
AJC
G1EN
turned out they did not have one, and if they did
it would of been £102
Old May 24, 2006 | 11:40 PM
cos im worth it's Avatar
cos im worth it
On here to much!!
HI DOES ANYONE KNOW IF THE INVERTOR CONTROLS THE DIMMER? MY CLOCKS KEEP DOING THE ON-OFF ANOYING THING. THEY SOMETIMES COME BACK ON IF YOU MOVE THE DIMMER. IS THIS THE SAME PROBLEM AS THE NACKERED INVERTOR? THANKS ( PITCH BLACK DRIVER)
Old May 25, 2006 | 03:28 AM
The Youth.'s Avatar
The Youth.
the inverter is deffo the cause of your problems
steve
Old May 25, 2006 | 04:19 PM
kjc300's Avatar
kjc300
https://passionford.com/forum/viewto...662&highlight=
Old May 25, 2006 | 10:13 PM
cos im worth it
On here to much!!
the youth
THANKS MATE, I KNOW EVERYONE HAS SAID YOU CANT BUY THEM FROM FORD ANYMORE, IS THERE ANYWHERE THAT DOES ONE THATS THE SAME AND HOW HARD OF A JOB IS IT TO DO? CHEERS MARK.
Old May 26, 2006 | 08:32 AM
Tandy's Avatar
Tandy
if you do a search of my old posts there is one on the invertor, i replaced mine from rs relectrical supplys and cost me about £25 cheers
Old May 26, 2006 | 11:37 AM
cos im worth it
On here to much!!
Tandy THANKS MATE YOUR A STAR, WAS IT AN EASYISH JOB TO DO?
Old May 26, 2006 | 02:08 PM
AJC's Avatar
AJC
mine came through the post today
thank you every one
Old May 26, 2006 | 08:13 PM
Tandy's Avatar
Tandy
if you can solder it's not a problem but i had a mate do it for me goodluck
Old May 26, 2006 | 09:42 PM
cos im worth it
On here to much!!
Tandy CHEERS. I'LL KIDNAP MY DAD, HE USED TO DO THE OLD SOLDERING CARRY ON FOR A JOB HE DID BEFORE.
Old May 26, 2006 | 10:34 PM
cos im worth it
On here to much!!
AJC HI MATE, WOULD YOU BE ABLE TO TELL ME WHERE YOU GOT YOURS FROM? PHONE NUMBER OR WEB SITE, THANKS.
Old May 27, 2006 | 09:52 AM
The DIVA's Avatar
The DIVA
RS components.....
Part No:267-8863 £25.48
Should do the job matey...
www.rswww.com
Old May 27, 2006 | 05:28 PM
cos im worth it
On here to much!!
nightdavva THANKS ALOT.
Old Sep 8, 2006 | 01:37 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
bttt, any ideas where/if i can still get these??
Old Sep 8, 2006 | 05:47 PM
AJC's Avatar
AJC
my old clocks on ebay at the moment,
inverotr did not work for me
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
cozzzzy power
Sep 4, 2015 08:14 AM
hopper350
Sep 4, 2015 12:53 AM
turbowag
Sep 3, 2015 08:07 AM
