My XR4i mk2 Trackcar
Old May 20, 2006 | 01:24 AM
robrs2's Avatar
robrs2
Default My XR4i mk2 Trackcar
I have been putting this thing together for a bit now and i hope to have it completed soon so heres the story so far.
Car: XR4i 2.0 Dohc. LHD Spanish import
Mods:
Stripped out with 6 point through dash cage.
4x4 Cossie rear axle, fitted with 2wd brakes, polybushed and AVO Coilovers
XR4x4 front hubs with driveshafts removed from cv's. Tarox groved XR discs and calipers. Avo coilovers, Adjustable TCA's, Polybushed.
Eccentric rose jointed top mounts.
Saff side skirts and front bumper.
2.9 24V Cosworth V6 fitted with a modded XR4x4 box converted to 2wd.
Here are a few pics
Old engine 2.0 Dohc
New engine
V6 2wd box
And as it is now with the cage fitted
Old May 20, 2006 | 03:46 AM
Benni's Avatar
Benni
Ban[B][/B]ned
Looking good so far
Old May 24, 2006 | 10:39 AM
GazzaG's Avatar
GazzaG
nice one mate
Old May 24, 2006 | 08:26 PM
Richie.'s Avatar
Richie.
aka Turbosailorboy
From: Under the water.... .......in a nuclear submarine
Looks nice
What sort of cage is that
Old May 24, 2006 | 09:39 PM
Like the look of the late spec ,as a three door good old mainland europe spec
Old May 26, 2006 | 04:39 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
Looks good
Old May 27, 2006 | 07:00 AM
Mr RS500's Avatar
Mr RS500
Looking good Roberto
Cage looks
Old May 28, 2006 | 12:47 PM
robrs2's Avatar
robrs2
Thanks all The cage is by Protection and performance in Skipton. Its a 6 point bolt in built to the new MSA regs which require the rear diagonals to be in the main hoop. Its well solid too
Old Jun 30, 2006 | 07:47 PM
robrs2's Avatar
robrs2
At last got the dam thing running Had some problems with wiring but all now ok. What a nice sound the V6 makes I think the neighbours may soon get pissed at my reving it up
Still got a big list of things to do before Croft on the 9th July. Bigger brakes, Coilover ,e.t.c.
Pics up soon
Old Jul 4, 2006 | 09:28 PM
robrs2's Avatar
robrs2
Started fitting the rear Cossie 2wd discs.
The old XR discs
The new discs
The gap at the back
It turns out i was given RS2000 4x4 discs as the box was marked up wrong , New discs now on order.
Old Jul 5, 2006 | 04:01 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
That looks fucking coooooooool
Id deffo nob the whaletail off tho, reckon itd look lot nicer without it.
Old Jul 5, 2006 | 05:25 PM
robrs2's Avatar
robrs2
At the moment the fin is off, as i can't get the garage door shut with it on
New discs turned up BUT the wrong ones again This time XR4x4
Another set turning up tomorrow and only 4 days to croft
Old Jul 11, 2006 | 10:29 PM
robrs2's Avatar
robrs2
The almost finished look, Saff bumper still to go on.
And a bit to much camber on the rear.
Old Aug 1, 2006 | 04:05 PM
NExr4i's Avatar
NExr4i
I Want To Be FOOOOOSED..!
realy nice project
Old Sep 4, 2007 | 03:31 PM
Cawood's Avatar
Cawood
thats fucking ace!!! love it mate!
think it looks loads better with that front end over a 3dr
get your cage done in skipton, north yorks? thats next town on from me
Old Sep 4, 2007 | 07:46 PM
robrs2's Avatar
robrs2
Yep got it from Skipton, one hell of a drive with a trailor.
Did some big changes to the car. One was converting to RHD
Some pics
Bulkhead out.
This may not catch on
The finished job.
Well a lot of work went in to the car before Croft due to knocking out the bottom end bearings at Donington
The BOA is now stuck on an engine stand. Its now been changed for a BOB 24V, but running off the BOA ecu and loom
Well it stood up to 2 days at the Durham and Derby Trackday. I had a blast
It still handles like shit, but its fun.
After letting Paul Linfoot have a drive in his words "its fucking lethal, but fun"
I think the rear beam or one of the arms is bent, so tme to change them out
Big thanks to Paul, Northyorkshire RS Spares for letting me butcher a Saff for the bits
Old Sep 5, 2007 | 05:34 PM
-beefy-'s Avatar
-beefy-
formerly beefy-rst-2
ive been out with rob in this car and its the fooking nuts !!!!
you drive like a bloody loon , and your drifting skills have come along way fella lol
great car and plenty of go in it too
what more you got planned for it fella
Old Sep 5, 2007 | 10:49 PM
robrs2's Avatar
robrs2
T3 + T3
Work that one out.
400 horses
Old Sep 18, 2007 | 08:15 PM
mad dog younge's Avatar
mad dog younge
first time i have seen the build rob you work hard aswell mate
Old Sep 19, 2007 | 12:06 AM
robrs2's Avatar
robrs2
I like to put a bit of effort in now and then.
Rolling road print out for the BOB motor
Old May 21, 2008 | 08:41 PM
robrs2's Avatar
robrs2
A small rebuild and time to fix all the broken bits before the Durham Derby RSOC day at Croft
Its always been a bit of wild ride and some what unpredictable. So after some poking about i found what may have been the problem.
The rear axle was from a Saff 4x4 an due to a short deadline for Croft 2 years ago i had to just fit the axle without checking it.
I have now found it had been fitted with one arm from an xr4x4, these are a different camber and toe to the 4x4 cossie one. End result the wheel pointing in different directions
In the pic you can just see the difference in the bushes fitted to the standard cossie arm (bearing type) and the rubber ones on the xr arm.
XR arm nearest in the pic
So time to fit my spare 7 1/2" beam and some xr4x4 poly bushed arms. The diff is a welded 7 1/2" with big flanges so i can use the thick driveshafts. The hubs are Scorpio ones with vented discs, same as the 4x4 cossie. And a 18mm 4x4 ARR. And some new 400lb rear springs.
Now onto the front.
The TCA's are adjustable and for sometime there had been a knocking coming from them. One of the rose joints had worn out, new ones ordered and fitted.
And refitted, As you can see i run 4x4 hubs but with the shafts removed. They give a wider track with the xr4x4 hubs.
Only the seats to re-mount, starter to change and some new stickers to fit.
Old May 23, 2008 | 09:07 PM
BRIGSPORT's Avatar
BRIGSPORT
UNAUTHORISED DEVELOPMENTS
Looking good. Keep an eye out for my glsi of death,hopefully running v8 power, 909 coilovers,adjustable beam,ap's etc. I dont do drifting too well though. What group you in at croft?
Old Jun 9, 2008 | 10:52 PM
robrs2's Avatar
robrs2
Group C
Got the seats back in and decided that the inside looked crap. So without repainting the floor the only thing was to put a carpet back in.
Also adjusted up the TCA's, big camber but ran out of adjustment on the steering so can't get it to track right. Going to have to reduce the camber a bit until the toe comes back to zero.
Old Jun 10, 2008 | 09:45 AM
MrCapriScort's Avatar
MrCapriScort
Old Fords Never Die
Great project matey
Old Jun 10, 2008 | 08:18 PM
BRIGSPORT's Avatar
BRIGSPORT
What length and poundage springs you running on your coilovers mate?
Old Jun 10, 2008 | 08:24 PM
rostill2007's Avatar
rostill2007
love the lhd to rhd conversion looks a very good job aswell keep us updated
Old Jun 10, 2008 | 08:59 PM
BRIGSPORT's Avatar
BRIGSPORT
My car will now be running standard 12v v6 power. Make sure your rev counter works this time rob!
Old Jun 12, 2008 | 08:46 PM
robrs2's Avatar
robrs2
Fully working rev counter taped to the cage
I had the springs that came with the avo coilovers, 320lb 8" front and 220lb 11" rear. They were too soft for the track. Fitted 500lb front and the 320lb on the rear. Worked ok but still too soft on the rear and they were too short causing the rear to be too low.
Added some shortened standard springs as well and that worked better so i have now got 400lb 12" on the rear. Not tried it yet but should be about right.
Also i run a 4x4 cossie rear roll bar 18mm and a Dohc sierra front roll bar.
Jacked it up to check the steering rack and with the front left less than 4" off the floor, only the opposite rear wheel was still on the floor . Think its stiff now
Old Jun 12, 2008 | 09:26 PM
BRIGSPORT's Avatar
BRIGSPORT
I'll be running 909 bilsteins, with a rose jointed solid mount rear beam, otherwise it will be standard 4x4 stuff with poly bushes,and will hopefully sort out some springs this week.
Also running competition kumho ecstas.
Look forward to seeing you at croft, we must have a chat.
Old Nov 19, 2011 | 09:28 PM
robrs2's Avatar
robrs2
Default 3 door trackcar up date.
Well feel i need to do a bit more to my sierra. Its had a few years unchanged and be reliable but think it needs a bit more power.
Also need to change the looks a bit, well may do.
First got a bit sticker happy before Croft RSOC show this year and it went from this
To this
Realy not to sure on it. Spotted a forza thread and went form there.
or could go and copy Ade's saff
Think the twin lights need to go too? which way?
Boot spoiler. At the moment is a Saff one. But i like the big wing look also on the forza thread
Then the engine. Its still got a BOB 24V cossie in. How it has taken the punishment i dont know. But it needs a bit more go.
So i have a pair of R33 GTR turbos. Hopefuly that should pep it up some. Looking to run .8 bar boost and see what happens.
The turbos to go on.
Also on the cards is an adjustable rear beam and wider wheels
Old Nov 20, 2011 | 02:21 AM
Dan j's Avatar
Dan j
Van modder
Love it long time
Old Nov 20, 2011 | 12:38 PM
I thought it was quick enough as it was Rob. Will you have to change rhe pistons for the turbo conversion.
I think you should keep the morretes.Will be a good cold air feed for the turbos.Would look cool with 2 air filters behind the lights
Old Nov 20, 2011 | 08:28 PM
robrs2's Avatar
robrs2
Engine is stopping standard, just getting air rammed into it
Old Nov 20, 2011 | 09:04 PM
BRIGSPORT's Avatar
BRIGSPORT
Just picked up a twin turbo engine for my sierra, but as for track work, a mk2 fiesta hillclimb car is now the weapon of choice.
Do the 12v turbo manifolds fit the 24v?
Old Nov 20, 2011 | 10:14 PM
JohnnyB's Avatar
JohnnyB
To this
yep,you can get 320BHP on a standard engine, adding some forced air, and a little Megacum management, not bad power at all, you may get 350bhp for a bit on standard compression with a good map.
Old Nov 20, 2011 | 10:40 PM
robrs2's Avatar
robrs2
No. The 12V only have 2 ports each side.
I started on a single turbo manifold to fit a T3 on. But i was told by someone running one that it runs out of boost quick. There are other big turbo's for a single turbo use but as the GTR turbos were £100 i'll start with them.
The single turbo manifold i started. This was to mount the turbo at the front passenger side of the engine. With a link pipe to the drivers side.
Old Nov 20, 2011 | 11:01 PM
skinnarbi's Avatar
skinnarbi
Tyres - It's What I Do
How hard is it to convert to BOB on the BOA loom and ecu? Is it worth the effort?
Old Nov 21, 2011 | 08:35 PM
robrs2's Avatar
robrs2
There are about 8 wires to extend on the BOA loom to fit the BOB. TPS, IACV and coil pack all need to be a little longer.
The BOB seems better than the BOA and does make more power. I dont have the Variable inlet working but if it is switched right then thats worth another 20ft/lbs+ on mid range power
Old Nov 22, 2011 | 01:41 AM
mk22door's Avatar
mk22door
Fart of the Purniture
If the car stays white then keep the twin lamps for air feeds as said but paint them black.
Was ye not selling it at one point? - You must've seen the light.
Old Nov 22, 2011 | 06:09 PM
robrs2's Avatar
robrs2
Lights were blue when I got them
Was going to sell it but having over £3.5k in it, no one was coming up any where near that.
