p8 or l8
iknow i asked this question before but cant find it??
what should i pay for a p8 iwanting to run antilag coil pack water injection air air and pectal boost cantrol???and how much is my l8 worth as imay be getting rid of it for a p8 also is the p8 better and faster program iv been told will all that lot and the ecu £1100 is this a rip off or just what they fetch???any info pls barry
If you have a P8, then speak to Ian Howells at Racetek, he can get this upgraded to 8-injector / ALS etc for £550.
Alternatively, we are about to launch and upgrade package for L8, which will make it fully live mappable as well as allow ALS and dizzyless to be used.
arr ok how long untill itl be finshed as i have a p8 and al8 here what should ido go down the rougt of the p8 or wait untill your l8 convertion comes out???witch is cheaper or better???
Its swings and roundabouts, as with the Pectel hardware / software required for the P8, you will be limited to who can map it.
With our hardware / software, ANYONE who is proficient at mapping could do it, and any future upgrades can be accomodated.
I would imagine that initially the L8 package will be more expensive, but then it will be cheaper and easier to map...
At the moment only those with the Pectel dongle etc can live map this, with our software ANYONE with a lap top will be able to do it. Basically it will convert L8 into a DIY mappable system
july1 i would wait and see if i were you.
the software with the RP Lab conversion is by the far the most user friendly that i have seen.
the benefit of using a modified L8 over something like Motec is that it is plug and play and has OEM reliability
This is exaclty what I said m8
But the Motec (like lots of it's competitor) has an adaptur to plug strait on the genuine loom
the good point with aftermarket is that they most have datalogging facilities, use wide band lambda sensors, and have help to built the maps (as well as base maps)...
they can run lots of injectors and coils..
I've also heard about a Pectel T4 but nothing really seems to move on there website.. Magnetti Marrelli also has very interseting stuff...
I want to change my gearbox before this step anyway it's worthless to have a big bhp engine without the possiblity of using it...
july1 converted L8 also has those features
check out the screenshots to see what features it has in terms of datalogging etc http://rplab.co.yu/Downloads/ICP_Too...orth_shots.zip
Originally Posted by Dave Henshall
whos making this conversion mike? is it s secs development or someone else, how will the rev counter output work with a coilpack enabled one.....??
). This is already fixed and comes as part of the conversion.
Dave,
Learn to read
Learn to read
sounds like he wants an ECU like mine.. that is for sale
@ mike
this bit....
but what i meant was is the system being further developed for the p8, so it can be live mapped without the pectel ...?does the l8 upgrade involve new hardware (ie a new board fitted) to enable this or is it just a new chip with this new software,...?
just for you mike
this screenshot shows you all things that can be datalogged and scoped
http://img.photobucket.com/albums/07...icp-rp-017.png
and can be used for the virtual dash
http://img.photobucket.com/albums/07...icp-rp-013.png
whislt you are connected by laptop/pc. this datastream could also supply a pectel style comms monitor of course. a feasibility study has been done already and production basically just depends on demand
