dont worry about breaking clips and fixings as you'll be breaking the welds instead, but if done properly it can look as good as when it came from the factory, ive seen it done on a s1rst and my god he did an awesome job but then again he worked at a panel beater all his life!!
Just pop them off mate, pull door rubber off, take the seatbelt off the B pillar, then pop off the b pillar trim, then pull trim panel away from metal, carefully
