Boost Pressure Small Turbo
Old May 12, 2006 | 08:54 AM
infinicar's Avatar
infinicar
Default Boost Pressure Small Turbo
All,
1995 Escort Cosworth Small Turbo:
On gauge, boost pressure needle travels to 1 oclock max (way before the hatched lines on the gauge). Performance feels slightly flat.
I fitted a variable boost controller to try and rectify temporarily - took it so boost needle reached the hatched lines - but there is a splutter, around where the needle used to stop before (1 oclock ish). Is that the overboost cutoff?
Any advice on correct boost pressures etc?
Thanks Paul
Old May 12, 2006 | 10:21 AM
cahzz's Avatar
cahzz
mine is standard and if i remeber correctly goes to the 1 oclock postion but mine feels very quick, i also own a small turbo model
Old May 12, 2006 | 10:22 AM
cahzz's Avatar
cahzz
i hope you havent just wacked on the boost controller and just upped the boost this is not the way to do it, infact its pikey and will lead to failure of one of the components
Old May 12, 2006 | 10:31 AM
infinicar's Avatar
infinicar
OK so boost pressure on dial seems OK then.
Variable controller only put on temporarily for testing purposes....off now.
Is going off to be fettled at some point....so will hopefully come back with a new lease of life
Paul
Old May 12, 2006 | 01:29 PM
cahzz's Avatar
cahzz
also mine spikes then holds the 1 oclock postition, i havent driven it for a while but i'll get it out later and have a go and tell you. i do no it should spike to 1.25 i think then hold 14-15psi, dont quote me on this but ive searched this alot and this is what alot of people are seeing on start cars.
Old May 13, 2006 | 01:46 PM
infinicar's Avatar
infinicar
Mine raises to 1 oclock (ish), and just stays there.
It feels a bit flat.......
Paul
3i Jim
Nov 20, 2015 05:12 AM
Matt Baxter
Sep 16, 2015 08:30 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
CrOwSoN15
18
Aug 22, 2015 10:24 PM
IAN RS2k
Aug 18, 2015 07:51 PM
