pic request: cossie clutch cable
May 10, 2006 | 07:42 AM
Hi all,
After receiving the wrong clutch cable for my cosworth yb (lhd, 2wd), I've ordered a new one.
If someone has a pic of the correct one, I can make sure that I'm getting the correct one from my dealer..
May 10, 2006 | 07:52 AM
isnt 2wd cltuch on the gearbox on drivers uk
you could try a 4wd one as there on passenger side hence switching them over for 2wd
may work duno
May 10, 2006 | 08:58 AM
4wd one is longer and is still available from ford. 2wd one is no longer available.
May 10, 2006 | 11:37 AM
Theres only one cable listed for LHD both 2WD & 4WD 6514375 could of been a wrong part in the bag worth ordering another one.
or you could try a 2wd RHD cable 1637438 still avab form ford.
May 10, 2006 | 11:40 AM
Quote:
Both still avab mate
1637438 2wd
6514373 4wd same cable for sierra & escorts
May 10, 2006 | 12:16 PM
but if its a 2wd rhd then its going to be too short as his clutch peddle is on opposite side to where it goes to teh gearbox
in theory its a 4wd one as these are on opposite side on rhd as it mounts on the other side of the gearbox compared the 2wd
or have i just tottally confused the issue
May 10, 2006 | 12:40 PM
Quote:
1637438 2wd
Will the 1637438 be correct for my lhd saff?
May 10, 2006 | 01:24 PM
Quote:
1637438 2wd
1637438 is only listed for RHD not sure if it longer or shorter or would fit a LHD ??
May 10, 2006 | 01:37 PM
Doo - thames valley ford have it as no longer listed. Both me and a mate had to buy the 4wd ones as thats all they had listed.
May 10, 2006 | 02:33 PM
just double checked mate and ford still have over 50 cables in stock and no plans to stop makeing them
May 10, 2006 | 02:34 PM
cool - so when I want a proper 2wd I will get it thru you if thats ok
May 10, 2006 | 03:33 PM
no probs mate
Jul 19, 2012 | 09:01 AM
R4N S S
Hi! Is the 4wd cable works ok on 2wd aplication?
I have 2wd LHD and need new cable. Here in Ukraine only 4wd RHD available from Ford with good price. Think to buy it. I think it will be just a little longer then for LHD, but this is not a problem and I hope will fit good.
Just tell me is the 4wd cable works ok on 2wd aplication?
Thanks!
Jul 19, 2012 | 12:31 PM
xr4x4rs
may work duno
No, 2WD release fork is on passenger side, I got mine from MSD.
Martin
Jul 19, 2012 | 01:10 PM
martysmartie
Martin
4wd also, so, will 4wd cable work properly at 2wd?
For LHD 2wd and 4wd cables are the same part number, I don't understand why for RHD is not...
Jul 19, 2012 | 01:14 PM
Get in touch with Stu @ Motorsport Developments on here, he sorted me out with a new one so I'm sure he could help you
Jul 19, 2012 | 01:25 PM
but I want to get OE genuine one
Jul 19, 2012 | 02:17 PM
I have the MSD one and it's fine
Jul 19, 2012 | 02:26 PM
COCHYN
I respect MSD, may be will buy it from them. Thanks!
jessie_rs
11
Jun 3, 2019 04:57 PM
Rs_Motion
Escort MK 5 / MK 6
43
Dec 27, 2018 11:49 AM
3drRich
Sep 13, 2015 07:32 PM
Aug 20, 2015 09:21 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
