ST3 on the dyno?
The problem is that the ECU doesn't let the boost rise over 0.2bar on the rollers. Tried to remove ABS and ESP fuses but it didn't work. The is equipped with Bluefin and Piper catback system. Does someone have any ideas? Local Ford dealer doesn't know why the car is acting like this on the rollers. The car is working just fine on the road.
its because its running 2 hot on the dyno and not simualating real life driving on the open road the best thing 2 do is 2 buy the radtec intercooler and that solves the problem!!!
That sounds weird IMO..?
Originally Posted by RichardC
we had a couple of focus Sts on the rollers at Jamsport, only issues were trying to get traction.
cheers Peter
Originally Posted by AKRS1
T4KAF could be right ive seen it on our st2 when its a hot day and the cars really hot it doesnt boost also rev limit is limited to aound 3.5k
RichardC:
What did you do to those st's before they where on the rollers?Original spec or what?
I think we have the problem solved.
Thx for the answers!
Originally Posted by Pumabuild
Put the car on the rollers and drive it in first gear slowly at about 7 mph after about 5 mins the ESP light will come. When this happens let the car cool for 10 minutes with the engine running and the cooling fans on the rollers blowing at the car.
When this is done you will be able to run the car as normal it is important you let the car cool as the intercooler is very small and ACTs get high on the rolling road
bigluke200
14
Sep 2, 2015 10:35 PM
