Turbo Rebuilding
I'm propper fucked off. I bought a Garrett GT28R brand new from the States last year, i've done about 6,000 miles, but have been running it at quite high boost (18psi - which it can't hold at the redline).
It's started smoking on the over-run. There is about 1mm in and out play on it, no side to side. The compressor wheels are fine and so is the housing. How much am I looking at for a re-build?
Originally Posted by GARETH T
could always DIY it
or send a pm to danny@radesigns on this board,....hes cheap as fook at the mo for rebuilds,.....will probably be a bit dearer when he goes international.....
Originally Posted by Red16
Originally Posted by burnout
Originally Posted by abdr500
diy a roller bearing turbo
yeah fair do's.....
i completely understand that,....but somethings are best left to people who know what they re doing,....
thing is,.....if he rebuilt it, ...wrong,.....and it went majorly tis up, hed be worse off, and more out of pocket for seal kit etc,....
however.....if he has a roller lying about that CAN be "broken by accident", then hes no worse off......get my point?
yeah fair do's.....
the same can be said about gearboxes, people always say fuck that theyre so complicated
but theres one lad off here (sorry i forget his name) that rebuilt his own rs turbo box
Danny doesn't do roller bearing turbo's.
I think I read before that you have to buy a new core if the seals go. If thats the case, it'll probably cost near enough the price of the turbo.
but a lot of people arnt......
hence him pm ing danny,.....turns out he s shit aswel....
You need equipment to balance it at 100 000 rpm. You got any ??
And in case of rallor bearing one it's core replacement anyway.
i rest my case,.....
but that was your opening statement,....
oh, i thought it was a figure of speech,...i mean, case closed.....
Originally Posted by bud-weis
How big is a GT28R then? my old T2 just struggled to hold 18psi and i can't imagine it's similar to that...and 18psi? wouldn't say that was high
I'll be fookin pissed if it's dead.
Is 1mm in and out movement usually enough to mean the seals are fooked?
taking something to a 'expert' doesnt always guarantee you a good job will be done,only way to be sure is do it yourself,but thats not always possible in something as specialist as this.
What does side to side movement mean - oil seals? or something worse?
I think I just killed my T34 last night and have some side to side movement in the shaft (but no front to back movement). . .
my t34 had play in side to side and in and out - safe to say it was fooked. Previously when I have had these turbos rebuilt I have only paid £250 but this time it cost me £530 (£450 + VAT) due to the damage I had done.
Still its back better than before with a few special bits so it should last this time
Originally Posted by safechav
Side to side means the bearings have gone and usually the whole turbo is fucked beyond a simple re-build
not sure what you mean there,.....
any turbo can be rebuilt,......however,...99% of the gt series need the core replacing,
so,....if its in and out,, it is very slightly possible its the seals,..but as its a gt it will need a core anyhow,....
if its side to side, it is more than likely the seals have been run down or failed.....most of the time,......... sometimes its the bearings, but these get changed anyhow in a rebuild,....(on a normal turbo) but as yours is gt, it needs a core...
so,...your options are,....it needs a core,...or,.....it needs a core.....
however,....fo the guy in america, your cans be rebuilt no probs, and is more than likely the seals or beaings,..
and seals and bearings get replaced in standard rebuild anyway....
i have rebuilt 2 roller bearing turbo's used t3 shart's and ground down
to size .i had to get my own balancing machine to balance the shart's
had one on my 620ti t04e compresser and a . 86 turbine and had no
problem other than melting the tip of the turbine
the other roller bearing is a t34 with a 48 turbine to fit a cossy
but drain and oil feed is t28
JK12
33
Apr 26, 2021 12:09 PM
Matt Baxter
Sep 16, 2015 08:30 PM
