Escort WRC Dyno graph
Originally Posted by bud-weis
but the torque figure ( i.e. what makes the car so damn fast ) will be enormous
Standard Cossie gearing and itd not be half as great, thats for sure.
Originally Posted by staffi
but as Martin says, torque is outragous
common misconception that the restrictor helps torque
the restricter does exactly what it says on the tin
I thought the Focus was 300 bhp / 225 KW ?
Torque is 395 LBS so not THAT massive really ( 535 Nm)
Its the XTrac 6 speed sequential that gives it its raw straight line speed
And they don't use Xtrac either
.Makes sense as the new rules forbid the use of computer-controlled front and rear diffs dont they?.
So will only the centre differential be ECU controlled, with regular mechanical units at the front and rear
The current Focus WRC claims 320bhp with restrictor, I can't remember the torque, but 550Nm seems to ring a bell....
I talked to some people that had a bit of experience with Focus/Impreza WRC and they say it's very likely in 350bhp range, but power is extracted by very very fine mapping,things like that. Also difference is visible between works and private cars. Torque is massive because of massive boost
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
