FAO people who know their 200sx's. itsmeagain?
Hello, couple of questions if anyone knows the answers.
What are the differences between the s13 and the s14, engine wise?
How is the engine mounted in the car? ie where are the mounts.
Right, lets go for some truth
Theres big differences (not jus looks) between S13 n S14 chassis too, but as you just seem interested in the engines, lets go there.
All UK spec and early Jap spec S13s had CA18DETs, 1.8 16v turbos, 170bhp, good for 250odd on standard turbo etc with a better cooler, 280odd on standard inj, 330odd on standard internals without any real probs, sometimes more if want, but not that common.
Jap spec ones had a different, less efficient head, but jap CA18s are pretty rare anyhow, as 90% of S13 180s and Silvias that have been imported are SR20 engined.
Late jap spec S13s, S14s, S14a, and S15s, came with various variations (mainly that S14/S15 had VVT, and inlet manifolds etc changed, but nothing much, id go for an early red top if was me) of the SR20DET, 2litre 16v turbos.
Good for 280odd on standard bits n a decent cooler, bigger bolt on stuff and can go for plenty more, 400+ has been done on standard bottomend good number of times.
CA18s have a kinda undeserved rep for doing big ends. They no worse at them than any other car of similar revs and bhp per litre.
Its just most of them have done a lot of miles and many not treated to well.
Ones that have had em replaced often has that done badly too.
Only dont see it on Cossies as they usually get rebuilt for some other reason long before they hit the miles where the big ends start to die!
My one lasted 99,000 miles before they went, and it was FAR from a pampered car, infact it was a cheap abused shed
SR20s big ends go too, and you see some like it now as they also often getting to 90k+ and led hard lives.
Ive seen ones last 130k with ease and abused to fuck though, so they do well when they want.
SR20s NEVER snap cams, ever, not unless they installed wrong, like any other car.
What they DO do is somtimes snap rocker arms, esp bouncing off the limiter for long times on modded cars.
To swap engines youd need all the bits, inc loom, manifolds, etc, jus like 90% of cars.
CAs and SRs arnt related at all, stuff like aftermarket intercoolers, turbos, exhausts, etc can be shared, but are all different as standard.
Mounts are one either side of the block, bolted on, which join to the chassis rails either side of the engine bay.
SR20 swap into a S13 is piss as late ones came with them, but ideally need a S13 SR20 box as it a bit smaller IIRC.
SR20 engine is a bit bigger in dimensions, but not by much.
Skyline RB20/25/26/30 engines fit in S13/14/15s without much grief too.
Tell me what you got in mind and i can prob help more.
Nope, mines an CA18DET. If this guy can be like this running an almost standard CA, so can I one day... maybe
http://futurenet.vo.llnwd.net/o2/uk/...Perfection.wmv
Like said, SR20 conversions are common and easy, and all later spec Jap S13s (180SXs and Silvias) ALL came with SR20s from the factory (different spec to S14/S15 ones tho, as per mentioned).
Mr.Worth on here has a SR20 engined Silvia actually.
One soo fucking cool id give my right bollock for actually...
http://www.passionford.com/forum/vie...ghlight=silvia
Steve your obsession with this guy is not healthy.
Mr.worths is cool as fuck though.
Originally Posted by Nomaderst
so the later s13s have the 2litre?
They carried on making S13s till 1998 in Japan, even though the S14 was in production side by side from 1994 (95? i forget, and dont care
), as they so popular.
Don't forget that the SR20DET engine has an Alloy block and timing chain, while the CA18DET has a Cast Iron block and a cam-belt.
Also, the SR20DET does muller cams when the oil changes have been neglected leading to blocking of the oil spray-bars, I think it was that which Tony was referring to.
That type of neglect is what causes them to destroy big-ends and also VVT pulleys (in SR20's).
The thing is, they were generally used by business men as a high-end sports-tourer and as such suffered poor servicing. It is only 2nd user onwards that they fell into the hands of enthuiasts, but for some engines this was too late.
Really the head gasket becomes a concern after 300ish bhp and really wants replacing with a thicker Metal one.
Originally Posted by Gary @ APT, your boss :DD:
snapped cams normally come from install error
Back when they was new S13s and S14s were mostly owned by businessmen and were high mile motorway cars.
Originally Posted by Escy
Just because the SR has an extra 200cc on the CA18 doesn't nessicarly mean it's a better engine.
Take good quality tubular exhaust manifolds as one prime example.
or you could actually use a turbo hangar like any normal person would with a big turbo and a stainless tubular manifold! the amount of people that dont use one is silly!
some people reckon the ca18 is better built than the sr20!
christian:NOT a dig at you at all there,but a lot of people tend to abuse their manifolds for being crap when they are trying to hang a massive turbo off it without additional help from a turbo hangar!there ARE crap manifolds out there,but some are ok,the people who use them just expect them to be able to take the stress of a massive blower hanging off them without bracing it
I know people with cars pushing over 400bhp thru cheapo 200SX ebay tubular manifolds for 20k miles and more and have NEVER cracked them.
You know why? Fucking bracing.
I know people who constantly smash mega bucks HKS manifolds on Evos and Skylines and having them welded all the time.
You know why? No fucking bracing.
My custom tubular manifold has braces underneath AND on top of the turbo.
Madness/stupidity not to run one on a tubular manifold.
Too true though.
mk3ste
Oct 17, 2021 10:09 AM
rsguy
44
Sep 29, 2015 03:29 PM
