What digital dashs are there?
The needle can flash as a shift light too, and all sorts of coolness. I nearly spunked when I went to there stand at Autosport.
http://www.spa-uk.co.uk/design/dashsystem.asp
Originally Posted by EssexBoyRacer
Why not use an TFT LCD panel and make up your own digital gauge. God knows where to begin writing the software though.
like the gems unit
i was going too have a go at doing one this year,, but i don't want to use external sensors, but de-code my can-bus from my ecu,,,, but sadly the can-bus is a little bit more complecated than i first though
Philip- TOTALLY agree, the Defi dashes are VERY cool
Oh dear me, how little you know about the business
Originally Posted by Ryan
good luck trying to get a freebie.
cant see it myself.
not like its a new product and they need the publicity
cant see it myself.
Tho im sure you will have some custom dash made up my an F1 team for your 6spd 4wd 350bhp zetec turbo budget track XR2
Originally Posted by PF Dave
What ECU are you running Dan? (Or you not got round to 'acquiring' that yet? LOL)
Why not a Pi X-Sport?
Not got any PF mags with me out here so cant read the right up again
PMSL @ Steve
I've got this in my Lotus.
Its by a company called AIM. It will take 8 analogue input feeds that you can configure to be what ever sensor you like. everything on the display is totally configurable and it will also data log everything. It will also take an RS232 feed from your ECU and datalog all of that info as well.
It does sooooooooooo much more than the best Stack and it does it all for less than half the price.
Sean..
Sean..
Originally Posted by cfoster
These are the clocks awaiting fitment into my mk2
. Just waiting for my electrical guru to power them up!
Chris
Chris
Chris
Chris
PMSL @ Steve
To me it looks like a cheap way of displaying all the info that you need to know about.
It doesnt look "bling" or "impressive" but thats what you would expect from a cheap product.
I know some people using them and they work pretty well
yeah i not knocking the fact that im sure it displays all the info needed.
also alot of these systems display what the ECU is telling them.
other dashes i.e STACK, uses its own sensors.
i suppose it depends what u want the dash to display, i.e what the ECU is seeing, or seperate readings.
