Boost Guage Help Pls
I need a boost guage for the Escos.
It needs to match the diameter of the Stack ST700 guage, ie 80mm Black face & rim - white numbers & red needle.
Would be ideal if the needle sat in the same position as the stack clock when idle.
Guess it needs to be a min of 30 psi & a manual (ie pipe on back type)
an pics or links would be appreciated
thx
dangerous
thx
dangerous
Originally Posted by dangerous - reyland
Paul - i couldnt see a Stack one on their website but have been told that they do an electronic one which is around £500
Have you looked on Demon Thieves website.
The Stack boost gauge is a Stepper no?
has a peak recall facility.. although I think its limited to as how long it holds memory for
you can also replay at different speeds
worth £300 imo IF thats the kind of gauge you're after
the elliot ones look pretty gypo to be honest
Broadmoor - Thx anyway will keep searching
Dave - i suppose if it comes to it i will have to spend the rent
I could be driving an Aston Martin convertible for the money this Escos has cost me
Watch me smash it up first time out
Jon - thx Dont want to spend that much on something that wont do the job
The problem with the Stack gauge is the readout.
The boost is scaled at 4 bar, so that it reads 3 bar boost, but idle sits at "1" on the gauge.
Sean used to have one I believe.........
its reads absolute presssure and not gauge pressure!
i would like that more myself
Mark RS
Oct 12, 2015 06:01 AM
PRO-LINE MOTORSPORT
Sep 28, 2015 09:54 PM
Russ Payne
Sep 25, 2015 08:29 PM
