Fuel light problem
Old May 1, 2006 | 07:07 PM
Speedy G.'s Avatar
Speedy G.
Default Fuel light problem
Found out that my fuel light is frequently lighting up although I know that I've got enough fuel in it because I just filled her up.
Problem occurs and goes away without any changes. Sometimes in downshifting, sometimes on roundabouts.
Very strange.
Does anybody have ANY idea???
Old May 1, 2006 | 09:00 PM
Kelv's Avatar
Kelv
Almost there!
do you notice that the gauge momentarily starts to drop when the light comes on?
if so you have either a dodgy connection to the fuel gauge sensor or its starting to play up...
have you recently had the tank out to upgrade or replace the fuel pump?
Old May 1, 2006 | 09:09 PM
Speedy G.'s Avatar
Speedy G.
Gauge doesn't drop at all, fuel pressure also stays the same.
Tank has been out but not recently --> about 1year ago.
Strange thing is also that I once ran her completely dry without the light coming on and now this.
Old May 2, 2006 | 08:50 AM
Cozzie Bhoy's Avatar
Cozzie Bhoy
Mine does the same thing. The needle starts to drop in mine when the light comes on. I'm going to change the full set up in the tank someday. After changing the fuel pump last year i just can't get myself round to stripping it all down again.
Old May 2, 2006 | 12:07 PM
yrkesman's Avatar
yrkesman
I just took my tank and fuelpump out. Mine does the same that fuel light blinks sometimes even when the tank is almost full and it usually does this till the tank is half full. I looked at the fuel gauge sensor when the pump was off and the surface where it reads the resistance was almost vanished so that's why it does blink the light. But I decided I can live with it
Old May 2, 2006 | 03:55 PM
Damo V's Avatar
Damo V
Sender unit...
the guage may not show a difference as it doesnt react as quickly as the light, but it is registering NO resistance, broken sender unit... quite common actually
Old May 2, 2006 | 06:20 PM
Speedy G.'s Avatar
Speedy G.
It does scare the shit out of me though.
Any idea on how to solve this without taking the tank and pump out again???
Old May 2, 2006 | 07:06 PM
Damo V's Avatar
Damo V
Take the tank and pump/sender unit out and replace
Damo V's Avatar
Damo V
Or take the bulb out the dash
Personally my car has never been low enough on fuel for me to need reminding by the light anyway
Old May 2, 2006 | 07:09 PM
Speedy G.'s Avatar
Speedy G.
That's the strangest thing.
My car has and then it didn't lit up.
Might have to take everything out again.
Old May 10, 2006 | 09:06 PM
Speedy G.'s Avatar
Speedy G.
This is getting annoying now as it's happening at quit a rate where sometimes my gauge now displays EMPTY as hell.
Might have to take the pump/sender unit out and replace that then.
Does anybody have a FINIS code of what I have to order?
Or can I still order that?
Old May 16, 2006 | 08:15 PM
Speedy G.'s Avatar
Speedy G.
No one?
Old May 16, 2006 | 08:39 PM
Malc50's Avatar
Malc50
Hi Speedy G
My Fuel light does exactly the same as yours, I only had y tank out last week to fit an 023 pump thinking I could check everything and sort tha problem at the same time. I measured the resistance of the sender unit and it all looked ok but still got the light on most of the time but the fuel gauge works perfectly
Damo probably got it spot on, replace with new unit to fix
Cheers Malc
Old May 17, 2006 | 08:26 PM
Speedy G.'s Avatar
Speedy G.
And what FINIS code does that new unit have please.
Old May 25, 2006 | 07:21 PM
Speedy G.'s Avatar
Speedy G.
Up for the code and NO, not the Da Vinci one.
Old May 25, 2006 | 07:39 PM
big-dirty-dog's Avatar
big-dirty-dog
are the units still avaible from fords????anybody know??
Old May 25, 2006 | 10:17 PM
alfacossie's Avatar
alfacossie
or does any body know where you can get 1 full stop?? as i need one to
Old May 26, 2006 | 10:59 AM
JHS's Avatar
JHS
My fuel gauge goes up and down, whatever it feel like it seems... Not had a light yet though... Did change fuel pump coulpe of weeks ago. Would be nice if someone knew what was wrong...
Old May 29, 2006 | 08:32 PM
Speedy G.'s Avatar
Speedy G.
Nobody???
Old Jul 8, 2006 | 08:43 PM
Speedy G.'s Avatar
Speedy G.
Back up after being offline for over a month.
van_dogg_pavvy
Mar 3, 2016 09:30 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
taylora1409
Aug 12, 2015 12:06 PM
dlwarrior
Aug 5, 2015 10:19 AM
Old ford
Jul 31, 2015 06:50 AM
