URGENT HELP PLEASE
guys i need yr help please,ive taxed the cozzy today and took it out for the first time since last october,and the brake pedal is rock hard
and the abs lights arnt going out
any ideas wot could be the problem ? im kinda guessing a bit but wot about the abs relay in the fusebox? could it possibly be that not putting power to the pump ? wot makes the light go out anybody know??
any help would be very much appreciated
im going mad here!!
any ideas wot could be the problem ? im kinda guessing a bit but wot about the abs relay in the fusebox? could it possibly be that not putting power to the pump ? wot makes the light go out anybody know??any help would be very much appreciated
im going mad here!!
sounds like the same prob i had,
check all the obviosu stuff and couldt find anything,,,,
turned out that the 2 thin red wires that come from the pos post of the battery then go into a larger red sheath that go along the top of the bulkhead... the copper had work harderned and snapped inside causing the pump not to run and symptoms as above. the insulation was intact though,,
only found it my mistake when performing a 'waggle' test had to chop back about 6" then add some new ends on, prob a lot like this with having the battery moved etc as its where they get bent back to make room, worth checking
many thanks guys really appreciate yr help, hey dave you might be right there because the only thing i have had off is the battery
so will be checking those wires. i will let you know wot it was when its fixed
DaveN
13
Jan 9, 2005 06:19 PM
