replacing tappets.
Old Apr 27, 2006 | 09:39 AM
trotty's Avatar
trotty
Default replacing tappets.
hi all,
when starting from cold, the tappets on my escos are ticking like mad!
i know it won't do any harm, but it really does sound rubbish!
as soon as it warms up its fine.
how easy is it to change them yourself??
anyone done theirs before?? cheeRS.
Old Apr 27, 2006 | 12:04 PM
rstoughy's Avatar
rstoughy
Easy Peasy M8,
Rocker cover off, time everything up and mark the pullys if you need to with a paint pen or something, slacken off the Timing Belt and remove from the cam pullys, remove the cam caps (take note of the order they are in) and cams and change out the tappets.
Re-fit in reverse order
Old Apr 27, 2006 | 04:51 PM
Damo V's Avatar
Damo V
Personally I would fit a new timing belt while doing it too
Old Apr 27, 2006 | 09:35 PM
S3an's Avatar
S3an
have you tried using a different oil, maybe a quick solution.
Old Apr 29, 2006 | 02:23 PM
trotty's Avatar
trotty
cheers for that everyone!
time to get the toolkit out.
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
