fitting big turbo t/b on small turbo plenum
Apr 25, 2006 | 09:42 PM
when fitting throttle body from a big turbo on to a small turbo plenum,how much work is needed?
could i do it my self or will i need specialist fabrication work done?
Apr 26, 2006 | 06:59 PM
Why? I ask because the big turbo throttle plate is smaller?
Apr 28, 2006 | 02:29 PM
Not much work required,just drill out the mounting holes for M8 clearance (8.3/8.5) and it is a straight fit.
Apr 28, 2006 | 08:29 PM
thanks,dose the throttle bracket still fit in the same place?
Apr 28, 2006 | 09:09 PM
As above mate.
all i did was drill out the holes and everything fits into place, just a tad close between the top of the tps and underside of the plenum.
Apr 28, 2006 | 11:43 PM
kelcos
what sort of power are you getting as i have a simular spec?
May 1, 2006 | 07:04 PM
i have no idea mate, not had chance of having it on the rollers.
May 5, 2006 | 07:34 AM
Small turbo throttle body is bigger. Why fit a smaller one from T34?
May 5, 2006 | 09:27 PM
just thought it would be easyer rater than mess about with the idle control etc
marky_g
Aug 15, 2015 10:43 AM
Blown Hell
Aug 5, 2015 07:22 AM
marky_g
Aug 3, 2015 04:45 PM
hazbaz1984
Ford Focus (All Models)
Jul 30, 2015 05:15 PM
