Red or/and Grenn EBC pads
Old Apr 24, 2006 | 07:22 PM
JanDK's Avatar
JanDK
Default Red or/and Grenn EBC pads
Help
Would I be a terible fool combining EBC red pads,in the front and green rear, on my EscCos, when I allready have themhere at home?
Or is it VERY importent that they are the same front and rear??
Old Apr 24, 2006 | 07:50 PM
big-dirty-dog's Avatar
big-dirty-dog
when i first brought mine it had greens all round,the fronts wore out so quick,i changed to reds for the front which were ok and had greens on the rear,all seamed ok,i waited till they wore down and then changed for reds on the rear too which was ok,i was told that the escos is to heavy of a car to greens away!!
Old Apr 24, 2006 | 10:11 PM
JHS's Avatar
JHS
I would use RedStuff if you really have to use EBC
Old Apr 25, 2006 | 07:30 AM
JanDK's Avatar
JanDK
JHS, hva slags klodser kører du med???
Old Apr 25, 2006 | 07:32 AM
JanDK's Avatar
JanDK
big dirty dog, ok.. nothing wrong with using what are on the shelf .. great
Old Apr 25, 2006 | 08:46 AM
JHS's Avatar
JHS
Kører ikke noe enda, skal hente min nye Escort neste uke, men har ikke noe god erfaring med EBC på mine tidligere biler
Kører du mye på bane?
Old Apr 25, 2006 | 12:34 PM
JanDK's Avatar
JanDK
Nej kører IKKE på bane ( kun om muligt for at lære bilen bedre at kende en dag) bruger bilen dagligt, så kan sikkert godt klare EBC eller Motorcraft, men motorcraft er dyrere end EBC.. så derfor kan jeg ligesågodt opgradere klodserne
Old Apr 25, 2006 | 01:20 PM
JHS's Avatar
JHS
Ok, men ikke greenstuff, redstuff er mye bedre Så køper du restuff bak neste gang også
Old Apr 25, 2006 | 08:05 PM
JanDK's Avatar
JanDK
Det LOVER jeg... I reeeaaaly do promise
Old Apr 25, 2006 | 08:07 PM
JanDK's Avatar
JanDK
Thank you, to both of you..
Old Apr 26, 2006 | 09:22 AM
JHS's Avatar
JHS
Old Apr 26, 2006 | 10:25 AM
Petrucci's Avatar
Petrucci
neither, they both are very bad pads. they destroy the discs in a very short time, and they don't have a good pedal feeling...
Old Apr 26, 2006 | 12:32 PM
JanDK's Avatar
JanDK
Oki.. that one I have heard from others... but but I already bought them, but it is NOT worth destroying discs al the time... Thanks.. will think it over
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
