problem with headlights.
Old Apr 24, 2006 | 06:50 AM
trotty's Avatar
trotty
Default problem with headlights.
hi all,
went to see a mate last night, when i came out to go home my main beam on the headlights wouldn't work.
full beam is fine, and so are the side lights on the outer lenses.
its done this once before but i just gave the lights a tap with my hand and they started to work again.
any idea's people??
Old Apr 24, 2006 | 05:40 PM
big-dirty-dog's Avatar
big-dirty-dog
ind/wiper stalks are know for being poo more than likely time for a new one if you can get one or strip it and repair if poss
Old Apr 25, 2006 | 04:14 PM
Damo V's Avatar
Damo V
Morrettes or std??
Either way, locate the std 3pin multiplug, unplug it and you will prob see a load of green corrosion, clean up male and female sections then see
Old Apr 27, 2006 | 09:34 AM
trotty's Avatar
trotty
all sorted!! turns out for some reason both bulbs had blown which i thought was a bit unusual.
never had both go at the same time before!
maybe one of them blew, then all the power went to the other bulb and blew that??
who knows???
cheers anyway guys and galls
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
