inlet?/
Old Apr 22, 2006 | 09:16 AM
barry0777's Avatar
barry0777
Default inlet?/
hi guy just bought a sweedish plenum for my ecos and just wonderd if you have to have it setn up after ifit it or will it be ok to fit a drive as im not taking the injectors or or anything???thanks all
Old Apr 22, 2006 | 10:54 AM
Mr C's Avatar
Mr C
I know you have to have the car re mapped for the extra air across the rev range, and to get the most out of it but not sure if it will damage the car if driven before hand though?
Old Apr 22, 2006 | 01:04 PM
sailorbob's Avatar
sailorbob
Big or small turbo Escort?
Old Apr 22, 2006 | 01:56 PM
Azrael's Avatar
Azrael
I would thnk it can become a bit lean, although you could probably get away with it I wouldn't risk. At least check wth wideband-lambda.
Old Apr 22, 2006 | 03:48 PM
barry0777's Avatar
barry0777
yes it the big turbo modal thing is iwas going to up the boost and put a differnt turbo on and injector so imay as well do all in one go ijust thought icould get away with it but if its going to run lean then i wont bother?
do you have to do the same even with the spacer??thanks all
Nov 1, 2015 06:53 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Johnny Knoxville
Sep 30, 2015 07:21 AM
Chopshop85
Sep 12, 2015 06:42 PM
