Horn not working
Old Apr 21, 2006 | 11:00 AM
Rocco's Avatar
Rocco
Default Horn not working
Hi The cars horn has stopped working & i need some ideas…
iv tested the switches in the steering wheel & when pressed they have power... then tested the wire going to the horn & its got no power so thought it may have been a fuse but after taking every fuse out they seem fine… so I need to know witch fuse if for the horn & any other action to take Cheers for your help
Old Apr 21, 2006 | 01:05 PM
Damo V's Avatar
Damo V
have you tried giving the horns a +ve supply to confirm they actually work?
Old Apr 21, 2006 | 01:49 PM
Azrael's Avatar
Azrael
On mine it was water in horns....
Old Apr 21, 2006 | 01:58 PM
Gary F's Avatar
Gary F
Think ya self lucky my horn sounds like road runner
Old Apr 21, 2006 | 02:00 PM
Azrael's Avatar
Azrael
milkman my sounds strange too... even though I bough complete new set from Ford 2 years ago...
Old Apr 21, 2006 | 02:05 PM
Gary F's Avatar
Gary F
I'm scared to use mine incase people start laughing at me
Old Apr 21, 2006 | 04:21 PM
THE RADMAN's Avatar
THE RADMAN
like damo says,just run a live and earth from the battery to the horn and see if it works for a start
Old Apr 21, 2006 | 04:27 PM
Cossie-Iain's Avatar
Cossie-Iain
Yeah mine goes meep meep roadrunner style aswell
Old Apr 21, 2006 | 05:30 PM
S1rst's Avatar
S1rst
I thought it was just mine!! Im scared to use mine its that bad!! Are they all like this then??
Old Apr 21, 2006 | 07:12 PM
Damo V's Avatar
Damo V
The reason they are making funny noises is because the horns are a pair, ie there is a high pitch and a low pitch, when one or the other fails, they will sound odd, they need to both be working at the same time as they need to be in "harmony"
Old Apr 21, 2006 | 08:41 PM
S1rst's Avatar
S1rst
Ahhh, looks like a job for tommorow then.
Cheers.
Old Apr 23, 2006 | 06:44 PM
Rocco's Avatar
Rocco
1st of thanks for your replies
iv tested the horns & 1 is working & the other is not... i take it from the replys that i should only need 1 to even get some sound & not both??
any other ideas??
cheers
Old Apr 25, 2006 | 11:49 AM
auralisRS's Avatar
auralisRS
clean the earths too, being exposed to the elements, its a common fault with any electrical item on a car.
Old Apr 25, 2006 | 03:59 PM
Damo V's Avatar
Damo V
The horns earth through the bracket / bolt fixing them to the body, as above, take it all off clean up etc
Old Apr 25, 2006 | 04:59 PM
Rocco's Avatar
Rocco
iv given the bracket + bolt a light sanding & still no joy
i then ran a direct live from the battery to the top horn & it worked.
is it the same fuse as the wipers??
thanks for the replies
Old Apr 25, 2006 | 05:05 PM
Damo V's Avatar
Damo V
electrical fault then... try kchecking circuit under steering colum shroud, to remove steering wheel as possible fault
Old Apr 25, 2006 | 05:12 PM
Rocco's Avatar
Rocco
oh well i will look at the steering column tonight.. iv already taken the surround off so shouldnt take to long
thanks
Old Apr 25, 2006 | 06:46 PM
Rocco's Avatar
Rocco
problem solved thanks for all your help
it was caused by 1 of the brass pin's on the indicator stalk getting jammed in
still all solved now
JK12
33
Apr 26, 2021 12:09 PM
Jack and the Beanstalk
Aug 15, 2015 04:27 PM
Old ford
Jul 31, 2015 06:50 AM
