white paste stuff on ignition amp heatsink
Old Apr 19, 2006 | 05:55 PM
MATCOS's Avatar
MATCOS
Default white paste stuff on ignition amp heatsink
Is this really important as I have had my heatsink bracket thing polished and dont have any-should I go to Ford and get some?
Old Apr 19, 2006 | 06:28 PM
Damo V's Avatar
Damo V
maplins
Old Apr 19, 2006 | 07:00 PM
sailorbob's Avatar
sailorbob
Get some back on there sharpish if you don't want your ignition amp to fry itself, the paste is a heat conductive paste.
Old Apr 19, 2006 | 07:21 PM
MATCOS's Avatar
MATCOS
Dont panic it's not on the road yet-I will go and get some sharpish
Old Apr 20, 2006 | 06:44 PM
MATCOS's Avatar
MATCOS
Originally Posted by Damo V
maplins
Whats it called please Mr Damo sir
Old Apr 20, 2006 | 09:23 PM
Damo V's Avatar
Damo V
Heat Transfer Compound
ˇexcellent non-creep characteristics ˇwide operating temperature (-50c to +130c) ˇhigh thermal conductivity (0.9 w/mk)-this silicone free heat transfer compound is for use on electrical and electronic components that require improved thermal conductivity or the efficient dissipation of heat. it ...
RE96E Heat Trans Comp 2ml 385 in Stock Ł2.49
http://www.maplin.co.uk/Home.aspx
Old Apr 20, 2006 | 10:59 PM
THE RADMAN's Avatar
THE RADMAN
i used to get mine from work,we used it on overheat stats etc on c/heating boilers
Old Apr 21, 2006 | 12:10 AM
infinityMJD's Avatar
infinityMJD
same stuff used on pc processor, can get it on ebay for pennies, just dont go putting a little smear on to keep it neat, gota go haevy with it
Old Apr 27, 2006 | 06:30 PM
MATCOS's Avatar
MATCOS
How much should I get is 2ml enough for my car?
Old Apr 27, 2006 | 06:34 PM
Damo V's Avatar
Damo V
yeah 2ml will be fine, I did two ign ammps with that and still had some left over
Old Apr 27, 2006 | 08:49 PM
MATCOS's Avatar
MATCOS
Cheers Damo
bobsworth
77
Mar 24, 2016 09:30 PM
gambo08
Feb 4, 2016 10:49 PM
jameswrx
Modellers Corner.
17
Oct 9, 2015 08:26 PM
SMILER258
Sep 28, 2015 09:04 AM
