ET40 wheels on a 2wd Saff....
Old Apr 18, 2006 | 09:46 PM
CharlieSaff's Avatar
CharlieSaff
Default ET40 wheels on a 2wd Saff....
What is the ET size for a 2wd Saff, and will ET40's go on ok?/How will they look?
Also does anybody happen to know is Masitaly wheels will fit 330mm disc's and AP 4Pot calipers behind them?
Cheers,
Charlie
Old Apr 18, 2006 | 10:02 PM
Ian M's Avatar
Ian M
i think you want et 35 on 2wd saffs.
Old Apr 19, 2006 | 05:15 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
I have Masitaly VT5s and VT7s on both of my 4is and the offset is 35
I don't know if the brakes will fit
Steve.
Old Apr 19, 2006 | 07:34 AM
dojj's Avatar
dojj
Resident Wrestling Legend
et35's are a bit much aren't they?
i have normally gone for an et40-41 and haven't had a problem
although in saying that, i'm running et45's with 15mm spacers on one of my sierra's and it required a little bit of arch rolling to fit
Old Apr 19, 2006 | 09:52 AM
CharlieSaff
The ones I'm looking at are ET40 Steve.
But if I use spacers that would help surely? Would ET40 wheels with 2mm spacers then be the same as ET38 for example?
Or is it not measured in mm's?
Old Apr 19, 2006 | 10:05 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Im sorry i don't know, all i can say is that both my sets are et35 and fit no problems
What wheel is it you are getting / got ?
Steve.
Old Apr 19, 2006 | 10:07 AM
R4N SS's Avatar
R4N SS
i have always used et35 on mine with no probs
Old Apr 19, 2006 | 10:10 AM
CharlieSaff
17" Masitaly VT5's
But I've been told the ET on them was ET40, and I was expecting them to be ET35. I thought they'd just not stick out so much?
I'm trying them on Sunday because obviously the brakes are an issue!!
Old Apr 19, 2006 | 10:30 AM
Ian M's Avatar
Ian M
the et measurement is in mms. whats wrong with your current wheels? they will take 330 aps no problem.
Old Apr 19, 2006 | 10:38 AM
CharlieSaff
I know Ian, the current wheels do have AP 4pot's and 330mm's on, but because of the front brakes the front wheels are pitted quite badly in some places. And I'm just fed up with it because nothing can get it off
And I think the Masitaly's will suit it just as well providing they fit
JK12
33
Apr 26, 2021 12:09 PM
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Alloy wheels and ICE for sale
14
Sep 26, 2015 05:40 AM
FlashRS
13
Aug 31, 2015 06:02 PM
cossynut2
Aug 19, 2015 11:29 AM
