Cold Air Feed
Ive just realised that I dont have a cold air feed to my Pipercross foam filter.
I assume its a must as with any other car with an induction kit??
How have others mounted them?? There doesnt seem to be much room down there.
Cheers, Rich.
Cheers, Rich.
if i was going to use an induction kit id use the standard ducting route, the hole under the drivers light aloow a perfect cold air feed, one of the reason why i personally think the standard airbox is very good at what it does, it also doesnt suck in anywhere near as much hot air.
ideally you want to get a air feed from down at the lower grill or something?
Johnny Knoxville
Sep 30, 2015 07:21 AM
Russ Payne
Sep 25, 2015 08:29 PM
