power steering
Old Apr 14, 2006 | 05:19 PM
cabman's Avatar
cabman
Default power steering
hi
don't know if any 1 can help me
i have a mk5b cab fitted a 2.0 zetec engine running Tb's omex ecu
the problem i have got is the steering
its sounds very nosie on any lock or just moving the steering wheel abit
i have replaced the rack and the pump
on the pipe from the rack to the pump
there is a valve or a pressure switch wot did go to the ford ecu
can this valve or pressure switch make the pas nosie
many thanks
Old Apr 14, 2006 | 06:42 PM
SafeChav's Avatar
SafeChav
I don't know a lot about power steering but im fairly sure thats a purge valve of somesorts. Its there for a reason........if its not connected then it could well be the problem.
Old Apr 17, 2006 | 12:39 PM
cabman's Avatar
cabman
hi
any 1
Old Apr 17, 2006 | 03:05 PM
sailorbob's Avatar
sailorbob
It was a pressure switch for the ecu to raise idle rpm to cope with the extra load when turning the wheel. Removing it won't be the cause of the noise. Are you sure the noise is coming from the rack, what about the steering column or top mounts?
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Iain Mac
Sep 30, 2015 09:39 PM
dojj
Sep 29, 2015 10:32 PM
