Focus ST Bluefin Now available - PF Discount !!!
RRP £499
PF users get 10% off and free P&P
£449 Delivered
Give us a call to order
Power Graph can be found here
Rob
£449 Delivered
Rob
Hi Rob
Couple of quick questions if you get time as I will be wanting a Bluefin unit, when the car eventually arrives LOL
1. I will be considering buying an after market intercooler will this make any difference to the map on the bluefin ie will it work well together or need a different map to suit?
2. Do I physically need to have the car in my possesion before I purchase the unit?
Many thanks for your time and keep up the good work.
Regards
Mike....
Regards
Mike....
Hi Rob
I’m looking to buy a bluefin this week
but like mike above would like to know if I change the intercooler, filter and maybe exhaust at a later date, am I going to need a re-map to get the best results?
Also is the warranty only valid on a totally standard car??
GREAT PRICE THO!!!!!!
but like mike above would like to know if I change the intercooler, filter and maybe exhaust at a later date, am I going to need a re-map to get the best results?Also is the warranty only valid on a totally standard car??
Performance fords car was running with a colins chip not a bluefin!
I'd like to know if this map was designed on a car without any mod's and then you could build up the spec as and when you had the money.
Max BHP on that car was 291 collins claim they can get 301 in their advert not sure if they do any other mods to get this tho.
Originally Posted by fireandskill1
Hi Rob
Regards
Mike....
Regards
Mike....
Hi Mike,
Thanks for your reply,
Ive not tested a car with and without an intercooler to be 100% sure but generally speaking it wont need a remap, but if we find that a diff map is required when fitting an intercooler i will update the units as required....
No you dont need to have the car in your possession to get a bluefin..... does help though
Originally Posted by ST EDDIE
Hi Rob
Yes the warranty is only valid when the car is otherwise std.....
Originally Posted by Simon Day
Top service from Rob
I got my Bluefin off him for my ST
The car is alot nicer to drive now (Even the Missus said so and she knows nothing about the driving styles of cars) As you are not changeing gear as much, The improved Torque does the work. Which also gives you 2mpg more aswell
It is also ALOT faster and pulls SO hard now
Just shy of 200BHP and over 300ftlb torque says it all
Worth EVERY PENNY Simon
wowk
Mar 30, 2021 07:49 PM
